Fusion 360 post processor file for Plamac
3 years 9 months ago #262523 by Doug @ Design8Studio.com
That is so cool. I have inkscape, and recently saw here on the site that there is a way to use it to output for plasma cutting. Amazing.
My longtime tool of choice for vector illustration (literally decades of use) is CorelDraw. I have an old copy functioning in a virtual machine that is fire-walled away from any cycle of obsolescence (LOL) or any internet viruses.
For designing sheet parts that are intended to be folded, and then flattening the plan for cutting, I'm pretty impressed with Fusion 360, although learning to use it has been challenging because I was entrenched and skillful in the SketchUp paradigm.
3 years 9 months ago #262524 by tommylight
For parts intended to be folded, have a look at "things made here" on youtube, adding a sharpie to plasma machines makes it very usable.
3 years 9 months ago #262525 by Doug @ Design8Studio.com
Yep, I've seen the very video you're talking about, and my plasma tool mount has a place to add a sharpie when needed, and I plan to let my floating Z do a double duty here, in that if the sharpie tip is positioned lower than the plasma tip, the floating Z should allow marking on the metal without the need of a separate spring tensioner mount dedicated just to the pen. My approach is a low-tech solution that is way easier and cheaper to do than the "things made here" hydraulic approach.
2 years 10 months ago #288863 by ashesman
I used the F360 post processor for the first time today.  I got it from  forum.linuxcnc.org/plasmac/38438-plasmac-post-processors#159042 .  Seemed to all work fine until I tried to run the generated g code in Plasmac (qtPlasmac).  I got some error messages about arcs not have correct start and ends on line 31.  So, I opened the g code in a viewer, and sure enough, the arc on line 31 is incorrect.
Did I mess something up, or is this a gremlin?   And yes, the part is what it looks like!  F360 and g code file attached.
2 years 10 months ago #288892 by rodw
I prefer to create a DXF file from the sketch and lay out with Sheetcam (windows or Linux). For a simple test you can use sheetcam in demo mode.
From your model, find the sketch in the tree and right click to download a DXF. If its a folded part, flatten it and then create a new sketch on it. Don't add anything to it and you can create a DXF
2 years 10 months ago #288969 by ashesman
Thanks for your suggestion. I did just download sheetcam and have a play. The price is not too offensive. Not the nicest of user interfaces, but didn't take long to figure out.
I cant see anything it does that F360 doesn't do. Maybe you can shed some light on this?
F360 does parametric nesting, so you can alter your part and it will automatically lay out the nesting again (note nesting is a paid F360 feature). There is also no mucking around with exporting/importing DXFs (assuming your part is drawn in F360). Your CAM can stay with a part, or an assembly where you automatically nest all the parts of an assembly. F360 has all the same options for inside/outside offset compensation (actually much more control over the cut path). Has a tool library etc.
