- Thank you received: 3
Almost, with cutter compensation active you should still use the F#<_hal[plasmac.cut-feed-rate]> as velocity based THC will still work.turbodude wrote: That's not good. I want to retain THC disable. So my tool table would have to reside in F360 so kerf width gets built into the gcode and PlasmaC would ignore its kerf setting. Conversely the speeds get pulled from PlasmaC due to the F#<_hal[plasmac.cut-feed-rate]> which is required to guarantee that any velocity related THC disabled are applied correctly (as you mentioned in another post).
Is my analysis correct?
It affects everything, it is an internal LinuxCNC limitation so it affect mills, lathes etcDo the same limitations apply if I buy SheetCAM or does it somehow handle things differently?
