GUI for PlasmaC - QtPlasmac
5 years 9 months ago #194684
Replied by rodw on topic GUI for PlasmaC - QtPlasmac
Snowgoer, I first compiled from source a few days ago and the SIM was working fine.
When I saw Robert's post I pulled the latest version and it raised the error I shared.
When Phill said he'd fixed it, I pulled again and recompiled and the error was gone.
Are you sure you are not waiting for the buildbot to do its thing? Or are you on a RIP version now?
- robertspark
- Thank you received: 216
5 years 9 months ago #194689
by robertspark
Replied by robertspark on topic GUI for PlasmaC - QtPlasmac
thanks all I am always a bit reluctant to report something as a noob it's probably going to be something I've done wrong.
5 years 9 months ago #194690
You undersell yourself there Robert.
robertspark wrote: thanks all I am always a bit reluctant to report something as a noob it's probably going to be something I've done wrong.
5 years 9 months ago #194695
by phillc54
TBH I haven't done any testing of QtPlasmaC on a package install, my bad. So you are the trailblazer for package installs.
Replied by phillc54 on topic GUI for PlasmaC - QtPlasmac
5 years 9 months ago #194705
Replied by tommylight on topic GUI for PlasmaC - QtPlasmac
Been using the buildbot install from two weeks ago, sim works fine, machine ..... i have it set up to a certain point but had no time to play with it as i used the time to install the designer and figure out how to use it as i need to make everything bigger, all my monitors are 1920x1200 so everything looks tiny on it.
Will try to update and report back.
5 years 9 months ago #194711
The current screen size is perfect for a 15.6" monitor like the ASUS VTI168H I use
Its 1368 x 768 which QTPlasmac supports
I found the 19" touch screen I put on the spaceship is far too big and the hand movement is excessive with Gmocappy as it forces you to move from the top right to bottom left just to start and home the machine. QT Plasmac is much better in this regard and does not require the homing screen to be slected as Gmocappy does.
Geez, I just realised I have not connected the touch screen to it!
Time to create page: 0.187 seconds
