Setting up a plasma cutter and looking for some help.
6 years 7 months ago - 6 years 7 months ago #160908 by Birdman3131
Ok. Thanks.
That just went from low priority to no priority. Can't get the motors to move at all with the mesa card when trying to set them up. Trying to figure out where I messed up. All the wiring looks right. (Only have x and y hooked up. All my z stuff arrives monday and limits can be done later.) May hook an oscope up and see if it is utputing the signals or not after lunch as it should work as far as i can tell.
Edit: I am on 2.9
Last edit: 6 years 7 months ago by Birdman3131.
6 years 7 months ago #160909 by PCW
Most common reason for no motion (assuming wiring is right) is too short step length
Start with 5000 ns
6 years 7 months ago - 6 years 7 months ago #161040 by Birdman3131
Is where it was when I left friday.
I have seen mention of firmware for the mesa board. Am I supposed to change it from what it comes with out of the box?
Is there any sort of enable I need to wire on the mesa board?
EDIT: 154 shows the step timing. www.teknic.com/files/downloads/ac_clearpath-mc-sd_manual.pdf (Should not need a log in as while they block the links behind a login direct links should still work. Let me know if different and I'll rehost.)
6 years 7 months ago #161044 by PCW
1. The supplied firmware should be fine unless you are using an additional
THCAD for ohmic sensing
2. The Teknics drives require that their enable input be asserted before
they will operate
6 years 7 months ago #161073 by Birdman3131
The drives are enabled. (I don't actually have the drives I linked. But the manual for the SC ones does not list the full step timings so I linked the other manual.)
www.teknic.com/files/downloads/ac_clearpath-sc_manual.pdf is my actual drives. They are enabled/disabled with a software command. At some point I need to figure out the actual code for that so I don't keep dragging my laptop out there to enable them but thats a later issue.
If I hook to the paraport breakout board it was working just fine.
I will mess with it more monday. I ended up leaving work an hour early friday as I was annoyed and did not see another hour helping my mental fugue at the time.
6 years 7 months ago #161208 by Birdman3131
So got back in here with a clearer head. Hooked an oscilloscope up to it and am just seeing a straight 4.65V output signal out of the mesa board rather than any pulse/dir signals. I am hooked to step0+, Dir0+ and both of the other wires to gnd (Same for step1/dir1 as well)
I can ping the board via the terminal but don't see a way to tell if pconf sees it. I know t does not give an error if I give it a bad ip.
Time to create page: 0.310 seconds
