Setting up a plasma cutter and looking for some help.
- Thank you received: 7463
23 Mar 2020 13:21 #161209
Replied by tommylight on topic Setting up a plasma cutter and looking for some help.
Hal and ini files, pictures, screenshots......?
- Birdman3131
23 Mar 2020 14:02 #161213
by Birdman3131
Replied by Birdman3131 on topic Setting up a plasma cutter and looking for some help.
Don't really have hal/ini files yet as I am doing this in the pconf wizard.
These are what I get when I finish the wizard.
1drv.ms/u/s!Anw0aD8CF6Z_huI2SZq2O2Z876C46Q?e=OVxbqD
I included the working para port ones as well. When I try to launch the mesa one I get a crash. I have included that as well.
- islander261
- Thank you received: 216
23 Mar 2020 14:44 #161217
by islander261
Replied by islander261 on topic Setting up a plasma cutter and looking for some help.
Post the results of running this in a terminal:
uname -a
Post your .ini and all .hal files listed in the .ini file.
Post the position of all jumpers on the 7i96 card.
From your description you have a configuration error and or running the wrong realtime kernel.
uname -a
- Thank you received: 5308
23 Mar 2020 14:46 - 23 Mar 2020 14:55 #161218
Replied by PCW on topic Setting up a plasma cutter and looking for some help.
The IP address in the hal file is very likely wrong
The default fixed 7I96 IP address is 192.168.1.121
The default settable (EEPROM) 7I96 IP address is 10.10.10.10
The only case where LinuxCNC would not be using one of these
addresses would be if the settable address was changed
This is normally only done if you have multiple Ethernet cards
in a LinuxCNC system.
Last edit: 23 Mar 2020 14:55 by PCW.
- Birdman3131
23 Mar 2020 15:07 #161219
by Birdman3131
The ip address was right earlier this morning. I changed it to see if it would give an error and forgot to change it back. I was at 121 for all my other testing.
Linux PlasmaCNC 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
Jumpers are all factory.
w2 right
w3 right
w4 right
w5 down
w6 down
w7 up
w8 up (This differs from default but i did not change it.)
I don't see any other jumpers.
Did I miss any files on the zip I uploaded?
w2 right
w3 right
w4 right
w5 down
w6 down
w7 up
23 Mar 2020 15:21 #161220
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=130#159240
That will not work for Mesa cards, you need the stretch version from the downloads page or the RT version from here:Linux PlasmaCNC 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
23 Mar 2020 15:23 #161221
"Linux PlasmaCNC 3.4-9-rtai-686-pae"
This a RTAI OS version, you need a Preempt-RT OS for Mesa Ethernet cards
Either the Stretch test ISO here:
www.linuxcnc.org/testing-stretch-rtpreempt/
or the Mint ISO (this may not be the latest)
drive.google.com/open?id=1I3C2zcFRlilkjQh1HKcAKKBQS1Z_5oOU
- Birdman3131
23 Mar 2020 15:24 #161222
by Birdman3131
Thanks. Will grab that and try again. Does it matter which one I get?
23 Mar 2020 15:27 #161225
If you have an older PC get the first one, if you do have a decent PC get the second one.Does it matter which one I get?
- Birdman3131
23 Mar 2020 15:34 #161226
by Birdman3131
Its a Pentium D so decidedly old.
Thanks again for all the help. I ignored the note about mesa cards on the download page because at the time a mesa card was not even a thought. It never even stuck around to be a niggling thought during all this troubleshooting.
Time to create page: 0.138 seconds
