Setting up a plasma cutter and looking for some help.
- Thank you received: 7480
Get the first one from there, the RT_PREEMPT one, it is Mint with XFCE so it is lighter and up to date.
- Thank you received: 4149
- Birdman3131
Gonna be a few days on the Z axis as the coworker I was told to ask for help has actual production work going. (Assuming my state does not shut down although as we make parts for the bottling industry to stay running we might be considered important.) Dunno. That's somebody else's issue.
1drv.ms/u/s!Anw0aD8CF6Z_huI7kfTt7fa1F0Wplg?e=686fgf is my stats although this was only running about 30 seconds.
- Birdman3131
Ohmic sensing.
I don't seem to have any opto relays that can use DC on the contact side. I do have a few That work with AC only and thus was going to have the mesa turn that on or off and have it control some standard coil based relays. This should still provide the protection needed for the board if I understand the purpose of the optically isolated relays on the diagram from the plasma primer. If i really need all the relays to be optically isolated I can look harder or order some but this seemed viable.
Cnc connections:
I can set ok to move to either be a relay contact (Default) or a DC voltage. Is there a reason to choose either? Thinking a voltage output seems better but I don't really know
The connections I should have are:
Mesa Outputs:
Start/stop
Ohmic sense enable (To the opto relay from above)
Mesa Inputs:
Thcad-10 as encoder input. (30:1 divider on a 180V plasma should be a 0-6v signal.)
Ok to move (I believe this is the same as arc ok)
Ohmic sense input.
Para port. (Tried hooking this the the mesa board but was not able to get it to work so its hooked to the pc directly)
All home switches. Was not sure I had enough room on the mesa board. This also gives me room for some physical control switches if need be.
onedrive.live.com/?authkey=%21ALTdAndnUh...5&parId=root&o=OneUp The description of the cnc connections.
- phillc54
- Thank you received: 2100
They should be isolated for safety.Ohmic sensing.
Don't let Rod hear you say thatI can set ok to move to either be a relay contact (Default) or a DC voltage. Is there a reason to choose either? Thinking a voltage output seems better but I don't really know
If your machine has the output, use that.
YepThe connections I should have are:
Mesa Outputs:
Start/stop
Mesa Inputs:
Ohmic sense input.
I'm not sure what you mean herePara port. (Tried hooking this the the mesa board but was not able to get it to work so its hooked to the pc directly)
Use them if you think it make life easier/betterAll home switches. Was not sure I had enough room on the mesa board. This also gives me room for some physical control switches if need be.
I would consider having a float switch as a backup for the ohmic and also a breakaway switch. They can be the one switch.
- Birdman3131
I did not spend long on trying it and just hooked it to the pc instead. I might email mesa if I get bored but I doubt it matters.
I do plan on a breakaway switch but a floating switch won't work with the holder we made. Not sure how viable it would be but there is a magnetic encoder on the linear stage I am using for the Z and depending on how plasmac/LCNC works it might be possible to watch the position of that and infer when the torch hit the table but unless ohmic probing fails a lot it sounds like a lot of work to set up. For now I am not wiring up the encoder.
Really hoping to see sparks tomorrow. (The good kind. Not the short circuited the 480v kind.)
Oh by the way I did find a bug in the PNCconf wizard. If you tell it you have a para port and then on the page for that para port tell it that it is set for input it ignores it when you actually write the files. It sets the pins correctly but at the beginning of the hal file I have to change it from "out" to "in". And of course because the wizard overwrites any changes I have to do it every time I rerun it. And I ran it a lot setting up homing and limits.
- phillc54
You should report this on the pncconf section of the forum.Oh by the way I did find a bug in the PNCconf wizard. If you tell it you have a para port and then on the page for that para port tell it that it is set for input it ignores it when you actually write the files. It sets the pins correctly but at the beginning of the hal file I have to change it from "out" to "in". And of course because the wizard overwrites any changes I have to do it every time I rerun it. And I ran it a lot setting up homing and limits.
- Birdman3131
