- Thank you received: 216
The motors are oversized torque wise as compared to the original ones allen bradly had on it. It has been a while so I don't recall the exact specs of the old motors.islander261 wrote: You say that you have two axis moving now. What type and thickness of material do you want to cut? What speed and acceleration can you get now? If you don't have a working LCNC configuration how are you testing you axis servos? Did you have the Teknic's sales engineer size your servos for you? If not you most likely didn't get the correct size for your table, it is much harder to correctly size servo motors for good performance than steppers. They may work now but the overall performance will never reach a servo driven systems potential.
I am definitely going to look into getting a motor for the lifter/repurposing the current one. Everything I find + what you are saying leads me to believe it is not the greatest.islander261 wrote: I used the Torchmate AVHC for Zaxis control for years and as Rod says it will not work correctly with the PlasmaC branch without serious hacking. Further more depending on the actual firmware version you have the cornerlock feature may or may not work even though the input is there. If you still really want to use the TM lifter assembly (Z axis mechanics and drive) the very expensive Smartmotor on it can be programmed to work as a simple step and direction drive like your Clearpath servos. The TM lifter is a POS really so build or buy a better one.
Just spend the money and buy a Mesa 7i76E and THCAD boards, you've already splurged on good servo motors. In the end you will be much happier with the results, actually no comparison really. Did I say the TM AVHC system is a true POS compared to the PlasmaC standard?
