- Thank you received: 2100
You should report this on the pncconf section of the forum.Oh by the way I did find a bug in the PNCconf wizard. If you tell it you have a para port and then on the page for that para port tell it that it is set for input it ignores it when you actually write the files. It sets the pins correctly but at the beginning of the hal file I have to change it from "out" to "in". And of course because the wizard overwrites any changes I have to do it every time I rerun it. And I ran it a lot setting up homing and limits.
Using names for them sorts this out, it makes for easier reading as well.If you are already using and2, you will need to add an extra instance of it which might change the index (eg. and2.0 might become and2.1)
