PlasmaC Fiber laser 1Kw head height control + auto focuas
03 Aug 2020 22:14 #177115
by Becksvill
Replied by Becksvill on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
taloot
I just read the data sheet on that plasma cutter www.jscut.cn/product/205_374
and it looked like it can cut 50mm plate. that is awesome. have you actually tried that thickness?
I think i really need to get into this
04 Aug 2020 16:57 #177261
by taloot
i do have video for actual cutting
Replied by taloot on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
taloot
05 Aug 2020 17:23 - 05 Aug 2020 17:44 #177410
by taloot
this is 3 main tabs
i will add monitoring for gas too
any tips will be appreciated
almost i fixed gas and laser operation
but i still have 1 problem need to be solved the best way.
the capacitance need to be calibrated at about 3 mm away from metal
and i want to probe directly to pricing height.
is it better for me to make new THC + ohmic component?
this is 3 main tabs
Last edit: 05 Aug 2020 17:44 by taloot.
The following user(s) said Thank You: Becksvill
06 Aug 2020 03:28 #177462
by phillc54
You could set the pierce height to 0.01 (it wont accept 0) and factor that out with the ohmic probe offset (it will take negative values) in the config panel. If cut height is the same as pierce height then set it to 0.01 as well.
Replied by phillc54 on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
If I understand you want to probe down and when it is 3mm above the material you want it to stop and that will be the pierce height. I assume the capacitive probe will tell you that it is 3mm away.but i still have 1 problem need to be solved the best way.
06 Aug 2020 07:52 - 06 Aug 2020 08:01 #177477
by taloot
so the probe pin should go high @ the pierce height
if
pierce is 3mm it will be 0.01
cut is 1mm so it will be -2.01
if
Last edit: 06 Aug 2020 08:01 by taloot.
06 Aug 2020 12:13 #177500
by phillc54
Sorry, I confused myself here.
If you use the ohmic input and your capacitive sensor senses the material at 3.5mm above the material then you would set the ohmic offset to -3.5, then you set the pierce height and cut height to what they should be.
There is one issue that I have just discovered. After PlasmaC senses the ohmic input it sends the torch to zero height which would touch the torch against the material. There is no need for it to do that so I will take a look at it tomorrow.
The following user(s) said Thank You: taloot
- Thank you received: 5925
06 Aug 2020 21:40 #177553
Replied by tommylight on topic PlasmaC modification to fit fiber laser rs485 control head capacitance Autofou
How much does a 1KW laser with power supply and head and whatever goes with that cost?
06 Aug 2020 21:46 - 06 Aug 2020 21:49 #177556
by taloot
main part you need
1 laser source price range 5000-7000 usd depends on the brand
2 lase head start from 450 - 1000 depends on brand and power rating also manual or auto foucus
3 chiller 750 usd
there no power supply its build in unlike co2
main part you need
3 chiller 750 usd
Last edit: 06 Aug 2020 21:49 by taloot.
06 Aug 2020 22:07 #177558
@taloot
Thank you.
Not bad at all, and since you mentioned earlier the power usage i got even more interested in this.
I am used to old type laser cutters that need 45KW of power for a 3KW laser.
Thank you.
The following user(s) said Thank You: shpatb
07 Aug 2020 00:25 #177562
by taloot
that was yag laser i guess with xenon lamp.. very bad technology
keep in mind u can pay 1000 usd and buy laser welding gun,,, u can use the laser source for weld and for cut
also there is 2 type one with feeder wire .. other not,, just diffused 2 sheet together,
@taloot
Thank you.
Time to create page: 0.173 seconds
