- Thank you received: 4153
Hypersensing questions
6 years 6 months ago #164668
Replied by rodw on topic Hypersensing questions
Great feedback thanks. From what I can see, its still possible to identify a probe event among the noise which is something nobody previously has thought possible when water enters the torch.
I think it would be good to see if you could use ohmic2 with a high threshold of say 23.95 to 23.99 volts to see if we can capture a probe event and also plot the ohmicsense.dbg_avgv pin which is smoothed by averaging. If we could do that, it might give us a baseline for the next step which is:
to change the component under case 1: from
to
We would then be using a smoothed moving average (N=5) which should flatten out the noisy peaks.
Eg. every reading is the average of the previous N readings. You may need to play around with N so:
If we then change the value of ohmicsense.num-readings (our N) to say 10, it will increase the number of readings averaged. I think that would mean that you would need to be reading 24.0 volts for 10 servo cycles before you saw a reading of 24.0 volts.
This all assumes my moving average code works! I think it does but its hard to test in an interrupt service routine on the servo thread. It will support averaging up to 1000 readings (1 second but we want to keep it as low as possible, certainly no more then N=100 which is 0.1 second.
Hopefully, that will give you some homework and an eventual solution .
if(ohmic_volts > ohmic_threshold){
if(avgvolts > ohmic_threshold){
- Thank you received: 5334
6 years 6 months ago #164672
Replied by PCW on topic Hypersensing questions
The best solution would be to to lower the sensitivity of the ohmic sense by adding a resistor between the probe and the table, raising the current threshold...
6 years 6 months ago #164673
Peter thanks, can you suggest a value?
PCW wrote: The best solution would be to to lower the sensitivity of the ohmic sense by adding a resistor between the probe and the table, raising the current threshold...
6 years 6 months ago #164677
With no load (other than the THCAD-5) the sense current is 50 uA full scale
If you wanted 20X that (1 mA) , 24K would work.
Assuming that it needs to withstand 300V faults, (where it would dissipate 3.75W)
a 24K 5W resistor would be a good choice
- snowgoer540
- Thank you received: 907
6 years 6 months ago - 6 years 6 months ago #164684
by snowgoer540
happy to:
I dont see how it's possible you were getting 2.3M ohms with everything unplugged from the THCAD, unless you were touching the meter probes with your fingers. Otherwise, assuming everything was bone dry, there is literally no connection between the shield and the ground of the either the machine, or the table with the input and output disconnected from the THCAD.
Try this for me, remove your shield, exposing the nozzle, and measure from the nozzle to the ground clamp of the hypertherm. This is how I am getting 16.54K ohm.
Replied by snowgoer540 on topic Hypersensing questions
Uthayne wrote:
rodw wrote:
snowgoer540 wrote: Does what I’m saying about the resistance even remotely make sense?
Kinda but no. Any additional resistance must be counted (eg raw arc voltage with 2 x 100 k Ohm resistors or the everlast divider board which converts a 16:1 divider to a 24:. BUt what does not make sense is the low resistance you are measuring compared with Myselfg and Ulethane as we had numbers in the MHz which are reported in this thread somewhere.
Unfortunately that conversation was in the other thread (getting difficult to keep track).
snowgoer540, can you mimic these measurements? This is what I measured the other day.
Code:Turned off all power to everything. Plasma cutter still plugged into wall, but off. 24v isolated psu is unplugged Thcad-5 input and output connectors, unplugged Wire on cap, resistance between torch shield and table: 2.3MOhms Wire removed from cap, torch shield to table, resistance is still 2.3MOhms Work clamp removed from table, open circuit, infinite resistance Plasma torch to work clamp resistance is 5.6MOhms
happy to:
Wire on cap, resistance between torch shield and table: infinite resistance (open circuit)
Wire removed from cap, torch shield to table, resistance is still infinite as the circuit is open
Work clamp removed from table, open circuit, infinite resistance (open curcuit)
Plasma torch to work clamp resistance is 16.54K(I assume you mean from teh nozzle to the clamp
Last edit: 6 years 6 months ago by snowgoer540.
- snowgoer540
6 years 6 months ago #164686
by snowgoer540
This is what I would have expected. I dont see how the code is solving the problem that the hypersensing is too sensitive. It has a path to ground of 16.5k ohms, so of course it can easily overcome that.
Again, Maybe we are trying to solve two separate issues simultaneously. But until we reduce the false trips due to water intrusion, I'm not sure what the code is going to solve. This part of the ohmic problem seems to be circuitry based. I am with Peter, it needs to be less sensitive. The voltage for water in the torch needs to be lower than the voltage for shield contacting workpiece sitting on table.
I'm willing to try the resistor thing to see what happens, I just dont have any 5 watt or 10 watt resistors laying around, I'll have to order some.
Uthayne wrote: I then tried installing ohmic2 but it would not let me probe successfully as it was being triggered before moving to probe height.
Time to create page: 0.146 seconds
