Photos
6 years 5 months ago #168496 by Uthayne
Replied by Uthayne on topic Photos
Sure, I guess I missed that part.
First I remove the dross from the back side with a 4.5" compatible wire wheel on a grinder, but I do not touch the top side. It is too aggressive and can be hard to get the scratches out later. Then I use a degreaser or mineral spirits to clean the oil off of the part, as well as any metal dust/debris from cutting. Once the part is at the stage, I'll switch to a 2" die grinder with a scotchbrite roloc pad. I prefer the red one (medium grit) as a general starting point, but will switch to the green one if I want the finish to be brighter. You could use 600+ grit and get it super polished and I'm sure it would look even better. Not something I have tried, but it would be nice looking I'm sure.
Keeping the angle of attack consistent and grinding in the same direction, I'll polish up the entire surface. Once this has been completed, I'll go back and add swirls if wanted. The cleaner and more brightly polished the surface, the better with these patinas.
With hot rolled, I do the same thing but remove the mill scale with muriatic acid (HCl) or sand blast it first, but it is a bit more work and the CR sheets are only a few dollars more for me.
The following user(s) said Thank You: phillc54, arcsynapse89
  • thefabricator03
  • New Member
  • New Member
6 years 5 months ago #168557 by thefabricator03
Replied by thefabricator03 on topic Photos
Awesome information, Thanks.
6 years 4 months ago #171733 by snowgoer540
Replied by snowgoer540 on topic Photos
Thought I'd take a minute to share my first paying job on the table I built. I don't have any recent pictures of the table, I'll have to grab one and post it later.
At any rate, I definitely couldn't have done any of it without the help of you all on this forum. Thank you.
The following user(s) said Thank You: phillc54, tommylight, Clive S, rodw, thefabricator03, bbsr_5a, pinder, arcsynapse89
6 years 4 months ago #171737 by bbsr_5a
Replied by bbsr_5a on topic Photos
looks almost like a laserCut
The following user(s) said Thank You: snowgoer540, arcsynapse89
6 years 4 months ago #171748 by snowgoer540
bbsr_5a wrote: looks almost like a laserCut
Thank you!
  • thefabricator03
  • New Member
  • New Member
6 years 4 months ago #171768 by thefabricator03
Powder coated?
Time to create page: 0.070 seconds
