Photos
6 years 2 months ago #176887 by Clive S
Replied by Clive S on topic Photos
phillc54 wrote:
rodw wrote:
phillc54 wrote: Be carefull Clive, if you do cut imperial gcode on a metric machine then you need to set up an imperial material to suit.
I'm sure he'll have to rebuild his machine with an imperial tape measure before he can cut it! .... :S
I think they are still available in museums. :laugh:
Yes you were right but I found one lurking in the dust and managed to setup up the machine.
The following user(s) said Thank You: phillc54, dvn4life1972, arcsynapse89
6 years 2 months ago #176894 by dvn4life1972
Replied by dvn4life1972 on topic Photos
Probably would've been easier to convert it with the dxf file instead. I still need to tweak the start points and leadouts a little bit on that cut.
The following user(s) said Thank You: billykid, Clive S
6 years 2 months ago #176897 by Clive S
dvn4life1972 wrote: Probably would've been easier to convert it with the dxf file instead. I still need to tweak the start points and leadouts a little bit on that cut.
Thanks. Would you mind posting dxf file for it and then it can be scaled. I am having trouble with my vintage tape.
6 years 2 months ago #176903 by dvn4life1972
Here you go. Should've known how "challenging" a real system of measurement might be for my esteemed forum friends :)
The following user(s) said Thank You: phillc54, Clive S
6 years 2 months ago #176904 by Clive S
dvn4life1972 wrote: Here you go. Should've known how "challenging" a real system of measurement might be for my esteemed forum friends :)[/quote
I agree but I don't have to stand on my head to read it. Thanks
The following user(s) said Thank You: dvn4life1972
6 years 2 months ago #176926 by dvn4life1972
The black powder coated one is laser cut from when I made these years ago. Unfinished HR is today on my table. I think I can still dial it in just a bit better (still have to install my desiccant air dryer and motorguard filter, and I can run it at 30A settings for better definition.
The following user(s) said Thank You: phillc54, tommylight, arcsynapse89
Time to create page: 0.117 seconds
