Photos
- Thank you received: 4149
24 Aug 2020 11:18 #179222
Great to hear...
Replied by rodw on topic Photos
Ohmic is really working great, near as I can tell. Yea, I was really worried about losing those, but I'm really happy with how it turned out.
Great to hear...
- snowgoer540
- Thank you received: 907
24 Aug 2020 11:33 #179225
by snowgoer540
Thank you!
I havent quite mastered SheetCam yet. SheetCam to me is probably like Fusion360 is to you
. So I ended up copying the file, editing it to remove all the text, and used that to cut the square at the end
I will consider one of those, the tape gun isnt too bad, but man the tape itself gets pretty spendy. Especially for the 969 heavy duty stuff! But if it works, might be the way to go.
Replied by snowgoer540 on topic Photos
Looks great. when I did something similar, I moved the text onto a seperate sheetcam layer and just cut the outline on Stainless or ally from the same file to put at the back.
To glue it together Look at the 3M ATG700 tape gun. Expensive but with the right double sided tape it will be permanent and never come apart. (they have a couple of different adhesive tapes)
Thank you!
24 Aug 2020 11:48 #179231
It'll work alright. We used it for years in the printing industry and often had people asking us what we used. But we did not need the exterior grade that signwriters etc use.
Don't remind me about my battle with Fusion! I have not looked at it for a few weeks!
But I did work out how to save a DXF from a fusion sketch and open it in Sheetcam. There are some good Sheetcam youtube tutorials from arclight dynamics (I think).
- snowgoer540
24 Aug 2020 11:55 #179236
by snowgoer540
Took me a bit to learn that you could save a dxf from a sketch, rather than trying to export as DXF which doesn't keep the size ratios. Fusion does some really weird things like that. Exporting STLs is awkward as well. One does it through the cloud and it takes forever the other does it immediately. But it really is good software for Mill CAM anyways.
I did catch that series, I need to watch it again, only a few things stuck.
- dvn4life1972
- Thank you received: 173
24 Aug 2020 14:51 #179248
by dvn4life1972
Replied by dvn4life1972 on topic Photos
You can just go to the sketch on the tree, right click, select save as dxf, and it will save it locally on your machine. Then open that file in Sheetcam and away you go.
- snowgoer540
24 Aug 2020 15:05 #179249
by snowgoer540
Yea, I'm there now, but where were you 3 weeks ago
Also, I'm one of those guys who leaves the CNC machine void of all programs that aren't required to run the table. Probably came from the Mach3 days when the computer could hardly handle Mach3 let alone anything else.
24 Aug 2020 19:58 #179269
Those days are well and truly over now you use Linuxcnc.
Install Sheetcam, a browser and connect to your network so you can access the Linuxcnc docs from your machine
- phillc54
- Thank you received: 2100
24 Aug 2020 23:13 #179284
by phillc54
Does anyone use a touch screen, if so what resolution?
Replied by phillc54 on topic Photos
My thoughts exactly, a machine controller is a machine controller.Also, I'm one of those guys who leaves the CNC machine void of all programs that aren't required to run the table. Probably came from the Mach3 days when the computer could hardly handle Mach3 let alone anything else.
- snowgoer540
25 Aug 2020 00:01 #179289
by snowgoer540
I don't, but if it helps you at all my screen is 1440 x 900. I have a touch screen for the Tormach Lathe, and I ended up unplugging the touch part, I hated it. But some people love it. Again, to each their own I guess.
- phillc54
25 Aug 2020 00:20 #179290
by phillc54
I don't, but if it helps you at all my screen is 1440 x 900. I have a touch screen for the Tormach Lathe, and I ended up unplugging the touch part, I hated it. But some people love it. Again, to each their own I guess.[/quote]
Thanks, just trying to get a feel for what resolution screen folk are using, my machines use 1600x900.
Time to create page: 0.144 seconds
