Photos
02 Aug 2020 04:15 #176877 by rodw
Replied by rodw on topic Photos
Be carefull Clive, if you do cut imperial gcode on a metric machine then you need to set up an imperial material to suit.
I'm sure he'll have to rebuild his machine with an imperial tape measure before he can cut it! .... :S
The following user(s) said Thank You: dvn4life1972, arcsynapse89
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Aug 2020 04:16 #176879 by phillc54
Replied by phillc54 on topic Photos
I think they are still available in museums. :laugh:
The following user(s) said Thank You: rodw, dvn4life1972, arcsynapse89
02 Aug 2020 07:51 #176887 by Clive S
Replied by Clive S on topic Photos
Yes you were right but I found one lurking in the dust and managed to setup up the machine.
The following user(s) said Thank You: phillc54, dvn4life1972, arcsynapse89
02 Aug 2020 10:03 #176894 by dvn4life1972
Replied by dvn4life1972 on topic Photos
Probably would've been easier to convert it with the dxf file instead. I still need to tweak the start points and leadouts a little bit on that cut.
The following user(s) said Thank You: billykid, Clive S
02 Aug 2020 10:28 #176897 by Clive S
Thanks. Would you mind posting dxf file for it and then it can be scaled. I am having trouble with my vintage tape.
02 Aug 2020 11:33 #176903 by dvn4life1972
Here you go. Should've known how "challenging" a real system of measurement might be for my esteemed forum friends :)
The following user(s) said Thank You: phillc54, Clive S
02 Aug 2020 11:36 #176904 by Clive S
Here you go. Should've known how "challenging" a real system of measurement might be for my esteemed forum friends :)[/quote
I agree but I don't have to stand on my head to read it. Thanks
02 Aug 2020 14:01 #176926 by dvn4life1972
The black powder coated one is laser cut from when I made these years ago. Unfinished HR is today on my table. I think I can still dial it in just a bit better (still have to install my desiccant air dryer and motorguard filter, and I can run it at 30A settings for better definition.
The following user(s) said Thank You: phillc54, tommylight, arcsynapse89
  • Moderator
  • Moderator
02 Aug 2020 14:36 #176930 by tommylight
Replied by tommylight on topic Photos
Nice, you had to remind me of Star Wars, now i have to go watch one or two of them ! :)
02 Aug 2020 17:16 #176949 by rodw
I'm intrigued by the file name now. Where is the butterfly footrest used?
Time to create page: 0.182 seconds
