Error after Update
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
29 Apr 2020 17:41 #166153 by snowgoer540
Error after Update was created by snowgoer540
Updated, went to cut a job, get the following error wrt pmx485:
29 Apr 2020 17:42 - 29 Apr 2020 17:44 #166154 by phillc54
Replied by phillc54 on topic Error after Update
If you updated LinuxCNC before late yesterday (my time) that would be the problem.
Try updating LinixCNC again now.
sourceforge.net/p/emc/mailman/emc-develo...ail.com/#msg36996185
Last edit: 29 Apr 2020 17:44 by phillc54.
  • snowgoer540
  • Moderator
  • Moderator
29 Apr 2020 17:50 #166156 by snowgoer540
Replied by snowgoer540 on topic Error after Update
hmmm. I literally just did it before I made the post (still standing at the machine)...
Also, before updating I was getting a weird "can't do that (EMC_TRAJ_SET_TELEOP_ENABLE) in auto mode with the interpreter paused" multiple times when running a 48.5 inch cut i made from the straight line conversational...
  • snowgoer540
  • Moderator
  • Moderator
29 Apr 2020 17:51 #166157 by snowgoer540
gitpull says "already up to date" :(
I disabled the pmx comms to get this job done, that will work for now. Still concerned about the weird error
29 Apr 2020 17:52 #166158 by phillc54
did you run make?
  • snowgoer540
  • Moderator
  • Moderator
29 Apr 2020 17:54 #166159 by snowgoer540
did you run make?
yep, in the src directory, followed by sudo make setuid, and then closed terminal opened rip'd enviro and checked configurator for good measure
29 Apr 2020 18:01 #166160 by phillc54
Sorry, I cocked up again.
I just pushed the fix.
  • snowgoer540
  • Moderator
  • Moderator
29 Apr 2020 18:06 #166162 by snowgoer540
Thanks Phill!
Also, any thoughts on the "you cant do that" error?
29 Apr 2020 18:13 #166164 by phillc54
Thanks Phill!
We aim to please...:)
Actually you were fortunate in your timing, I had just finished checking my emails and was about to head out for a few hours when your post turned up.
Not off the top of my head, that is something from LinuxCNC itself. I will have a look when I get back. Could you post a screenshot of the settings you were using.
  • snowgoer540
  • Moderator
  • Moderator
29 Apr 2020 18:19 - 29 Apr 2020 18:20 #166165 by snowgoer540
Thanks Phill!
Yea, will do. Dinner's ready, so after that!
I'm running into a few more errors:
1. The conversational is still cutting at 60% of the previous job's hole speed. I know someone else said that too. But I cut a 4 hole pattern of holes that were .4" diameter. Then I went to cut a 47" circle, after clearing everything, and it's still 60% of velocity (as can be seen in teh screen shot).
2. Despite choosing center and giving a start of X0 Y0, my circle is definitely shifted Positively about 2 inches in Y. The circle is not being cut around the center. Added Gcode here too.
Last edit: 29 Apr 2020 18:20 by snowgoer540.
Time to create page: 0.490 seconds
