Z axis probe height init
- jay1st
- Thank you received: 17
At every start of a pierce the Z axis goes all the way up to the limit switch before probing and it's time consuming.
Is there a way to avoid that ?
My Z has 70mm travel and i want to keep like that as i do cut some square pipes on the table as well
Tnx
- phillc54
- Thank you received: 2100
- jay1st
What parameter has influence on this behaviour ?
BTW probing by torch height, no ohmic sense yet.
- phillc54
- jay1st
- sevaz
- Thank you received: 5
And also I have a problem with IHS. It also doesn't work on debian 7(even on simulation install without any changes). On Linux MInt 18 everything works fine.
- phillc54
zip your complete config and post it here.i used 0 to have full retract before moving to the next start point, evn if i lower it to 10mm it will still go all the way up to the limit switch before probing
- phillc54
It shouldn't, do you do any Z jog moves or Z offsets.The same problem. Any value of the Probe Height causes this behavior. Also it goes up up to the endswitch. I think the reason is that sometimes plasmac looses track of Z position.
I have never tried on Debian 7 or Debian 8 for that matter. As it says in the docs it was developed and tested on Debian 9. If I get some spare time I may give it a try.And also I have a problem with IHS. It also doesn't work on debian 7(even on simulation install without any changes). On Linux MInt 18 everything works fine.
What do you mean by doesn't work?
- Thank you received: 7501
Debian 7, LinuxCNC version 2.7 has no external offsets, reverse run, so will not work, unless upgraded to 2.8 or 2.9
- phillc54
Thanks Tom, your post arrived while I was typing this...
