Z axis probe height init
- phillc54
- Thank you received: 2100
27 May 2020 00:29 - 27 May 2020 00:40 #169026
by phillc54
[DISPLAY] section
[AXIS_Z] section
You also have in the [AXIS_Z] section:and in the [JOINT_2] section:These should be the same.
In the Config Panel you have:That is way too high, it is measured from the [AXIS_Z]MIN_LIMIT which in your case is 5.0, this will send your Z axis up to the top limit (90) to begin a probe.
I would suggest that you set up your Z axis by following this: linuxcnc.org/docs/2.8/html/plasma/plasma....html#_initial_setup
EDIT:
You probably should also increase your Setup Speed in the Config Panel to as high as possible as you really want the machine to move from Pierce Height to Cut Height as quickly as it can.
Replied by phillc54 on topic Z axis probe height init
OK, I have noticed a few things that I think you should change in the ini file.here is my machine folder zipped
[DISPLAY] section
POSITION_OFFSET = MACHINEPOSITION_OFFSET = RELATIVE[AXIS_Z] section
MAX_VELOCITY = 30
MAX_ACCELERATION = 750MAX_VELOCITY = 60
MAX_ACCELERATION = 1500You also have in the [AXIS_Z] section:
MIN_LIMIT = 5.0
MAX_LIMIT = 90.0MIN_LIMIT = -0.0
MAX_LIMIT = 90.0In the Config Panel you have:
Probe Height 85I would suggest that you set up your Z axis by following this: linuxcnc.org/docs/2.8/html/plasma/plasma....html#_initial_setup
EDIT:
Last edit: 27 May 2020 00:40 by phillc54.
The following user(s) said Thank You: jay1st
- jay1st
- Thank you received: 17
27 May 2020 06:01 - 27 May 2020 06:06 #169033
by jay1st
Replied by jay1st on topic Z axis probe height init
Ahhh very nice and tnx a lot !!!!
I'll try that when i have time after work, maybe tomorrow
I never realized i had a difference in Joint values on the Z axis
And i think i changed the acceleration and velocity as sometimes the Z stepper was "chirping " if the accel was too fast, it's a small nema17 running a 15mm OD ball screw, it's all on bearings so it should have minimal efforts but still happens.
For a while i thought this thread was side-tracked
BTW what difference does make the POSITION_OFFSET from MACHINE to RELATIVE ?
Last edit: 27 May 2020 06:06 by jay1st.
- phillc54
27 May 2020 06:45 #169037
by phillc54
In MACHINE mode the DROs show the G53 machine coordinates.
In RELATIVE mode the DROs in the Preview will show the coordinates that you are using which is normally G54 so when you touchoff an axis to zero on a part then the DROs show the position from touchoff zero. You can then see the relationship of the DROs to the material.BTW what difference does make the POSITION_OFFSET from MACHINE to RELATIVE ?
- jay1st
27 May 2020 07:39 #169051
by jay1st
The DRO showed on the PLAMAC screen has 2 sets if i remember correctly, one is abslolute (MACHINE ?) and the other lines are the RELATIVE values after a touch off. Am i correct ?
- phillc54
27 May 2020 07:45 #169054
by phillc54
If you have View >> Show Offsets selected.
You can have it how you like, I don't like to see the offsets on the preview screen, just the x, y, z and Velocity.
- Thank you received: 7489
27 May 2020 07:56 #169059
Replied by tommylight on topic Z axis probe height init
+1I don't like to see the offsets on the preview screen, just the x, y, z and Velocity.
- sevaz
- Thank you received: 5
27 May 2020 08:07 #169062
by sevaz
Replied by sevaz on topic Z axis probe height init
Then I don't understand how the IHS skip option works, because in the plasma guide there is no explanation about it. So I suggested, that if the IHS skip is active, it shouldn't search metal sheet and assume that it's the same height like it was at the end of the cut(or at the beginning of the cut when thc is off) thus I shouldn’t activate float switch. But it seems, I am terribly wrong
- Thank you received: 4151
27 May 2020 08:12 #169063
Replied by rodw on topic Z axis probe height init
I've never used it but I think:
If you set a 50mm radius, and you need to start another cut within 50mm it won't probe again. I think also its assumed that the THC keeps it to correct height so if you start again within 50mm of the end of cut is won't probe either.
- phillc54
27 May 2020 08:27 #169065
by phillc54
- jay1st
27 May 2020 08:58 #169068
by jay1st
I've left it like that as i sometimes cut some square 50mm tube on the table, if set lower it does not probe the tube.
Maybe i should change it only when needed ?
In the Config Panel you have:That is way too high, it is measured from the [AXIS_Z]MIN_LIMIT which in your case is 5.0, this will send your Z axis up to the top limit (90) to begin a probe.Probe Height 85
Time to create page: 0.288 seconds
