Z axis probe height init
- phillc54
- Thank you received: 2100
27 May 2020 09:06 #169070
by phillc54
Replied by phillc54 on topic Z axis probe height init
You could set it so it just clears the 50mm tube.
PlasmaC is pretty good at high speed probing now so maybe you could try that as long as you have enough movement in your float switch.
Earlier you said that you made Z slower because it had some issues. You should have the JOINT_2 velocity and acceleration set to what the actual velocity and accelleration is that you reqire then set the AXIS_Z ones to twice that value.
The following user(s) said Thank You: jay1st
- jay1st
- Thank you received: 17
27 May 2020 09:22 #169075
by jay1st
Replied by jay1st on topic Z axis probe height init
I'll try that ASAP , or more like when i get the time to do it !
Tnx for the help !
Tnx for the help !
- Thank you received: 7489
27 May 2020 10:16 #169103
Replied by tommylight on topic Z axis probe height init
FYI, i have probing set at 4m/m and at 150mm high on a 185mm travel, with setup speed of 9.6m/m and max speed at 12m/m.
- sevaz
- Thank you received: 5
27 May 2020 12:04 - 27 May 2020 12:05 #169118
by sevaz
Yes, I saw it, but still can't understand how it supposed to work: because it still probes the height with the float switch even it's in the radius of the IHS Skip
Replied by sevaz on topic Z axis probe height init
There is a short description here.
linuxcnc.org/docs/2.8/html/plasma/plasma...-guide.html#ihs-skip
Last edit: 27 May 2020 12:05 by sevaz.
- phillc54
27 May 2020 12:13 #169119
by phillc54
I will check it out tomorrow.
- snowgoer540
- Thank you received: 907
27 May 2020 12:15 #169120
by snowgoer540
What exactly does IHS stand for?
Replied by snowgoer540 on topic Z axis probe height init
- phillc54
27 May 2020 12:17 #169121
by phillc54
Initial Height Sense
- snowgoer540
27 May 2020 12:25 #169124
by snowgoer540
Ah, I would have guessed “Search”. I work in the land of a bazillion government acronyms so I don’t assume anymore.
- phillc54
28 May 2020 03:01 #169185
by phillc54
Well not many folk must use that feature, I broke it last August...
Thanks for the report, it is fixed now.
forum.linuxcnc.org/plasmac/37233-plasmac-updates#169184
Then I don't understand how the IHS skip option works, because in the plasma guide there is no explanation about it. So I suggested, that if the IHS skip is active, it shouldn't search metal sheet and assume that it's the same height like it was at the end of the cut(or at the beginning of the cut when thc is off) thus I shouldn’t activate float switch. But it seems, I am terribly wrong
The following user(s) said Thank You: jay1st, bbsr_5a
- sevaz
28 May 2020 07:20 - 28 May 2020 07:21 #169200
by sevaz
Many thanks! I will try it within in week.
And I just realized we have been using PlasmaC for more than one year already and it's amazing. Thank you for your outstanding work!
Last edit: 28 May 2020 07:21 by sevaz.
The following user(s) said Thank You: phillc54, rodw, jay1st
