Z axis probe height init
26 May 2020 01:34 #168926 by tommylight
Replied by tommylight on topic Z axis probe height init
Since you have Debian 7 there, can you please try
sudo apt update
Getting complaints from users that it does not work without "apt-get", i did use it on Stretch and two iterations of Buster and it works.
Thank you.
The following user(s) said Thank You: jay1st
26 May 2020 01:39 #168927 by phillc54
Replied by phillc54 on topic Z axis probe height init
The same here I could use apt-get but not apt.
Synaptic reports apt as being installed (version 0.9.7.9) but does requires apt-get as the command.
  • jay1st
  • jay1st's Avatar Topic Author
  • Premium Member
  • Premium Member
26 May 2020 06:18 #168939 by jay1st
Replied by jay1st on topic Z axis probe height init
BTW i'm on Mint, and it's AFAIK the only strange thing going on.
This evening i'll stop at the shed and zip the config.
Maybe i have some wrong parameters somewhere
  • jay1st
  • Premium Member
  • Premium Member
26 May 2020 15:27 #168989 by jay1st
here is my machine folder zipped
26 May 2020 20:40 #169004 by sevaz
Replied by sevaz on topic Z axis probe height init
I run 2.9 on debian 7 machine.
26 May 2020 21:07 - 26 May 2020 21:07 #169007 by sevaz
Maybe I am doing something wrong. So I recorded a little video just to show you what Im talking about. This is default sim config without any changes. It's debian 7 (wheezy), default install, Linuxcnc from buildbot(ver 2.9.0 just updated 26.05.2020)
Last edit: 26 May 2020 21:07 by sevaz.
26 May 2020 23:09 - 26 May 2020 23:16 #169013 by phillc54
The video won't play for me.
It does if I go to you tube.
You need to press the Ohmic or Float button on every probe down, not just the first one.
If you run Buildbot and used a sim config then they won't update properly because the LinuxCNC config picker copies complete files, it don't copy the links. So you will need to open a terminal then run:
python /usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/configurator.py
then select Upgrade and find the ini file of the sim you want to upgrade then it should be right.
linuxcnc.org/docs/2.8/html/plasma/plasma...inuxcnc_installation
Last edit: 26 May 2020 23:16 by phillc54.
26 May 2020 23:13 #169016 by tommylight
Does it say to watch on youtube and offer the link?
It does exactly that here.
26 May 2020 23:17 #169017 by phillc54
We must have done that at the same time Tom. :)
26 May 2020 23:56 #169023 by tommylight
Yup, yup ! :)
Time to create page: 0.415 seconds
