- Thank you received: 2100
zip your complete config and post it here.jay1st wrote: i used 0 to have full retract before moving to the next start point, evn if i lower it to 10mm it will still go all the way up to the limit switch before probing
It shouldn't, do you do any Z jog moves or Z offsets.sevaz wrote: The same problem. Any value of the Probe Height causes this behavior. Also it goes up up to the endswitch. I think the reason is that sometimes plasmac looses track of Z position.
I have never tried on Debian 7 or Debian 8 for that matter. As it says in the docs it was developed and tested on Debian 9. If I get some spare time I may give it a try.And also I have a problem with IHS. It also doesn't work on debian 7(even on simulation install without any changes). On Linux MInt 18 everything works fine.
phillc54 wrote:
Debian 7, LinuxCNC version 2.7 has no external offsets, reverse run, so will not work, unless upgraded to 2.8 or 2.9sevaz wrote:
What do you mean by doesn't work?
