- Thank you received: 2100
phillc54 wrote: Initial Height Sense
sevaz wrote: Then I don't understand how the IHS skip option works, because in the plasma guide there is no explanation about it. So I suggested, that if the IHS skip is active, it shouldn't search metal sheet and assume that it's the same height like it was at the end of the cut(or at the beginning of the cut when thc is off) thus I shouldn’t activate float switch. But it seems, I am terribly wrong
This is one of those rare moments in life when saying "i told you so" feels so good !phillc54 wrote: Well not many folk must use that feature, I broke it last August... :blush:
Islander261 wanted that feature and I guess when you have 3000 pierces a sheet any probes you don't have to do could save a lot of time.tommylight wrote:
