Raspberry Pi 4 with PlasmaC
6 years 4 months ago #171283 by tommylight
It is parametric, so change the XY scale to make it bigger or smaller and set the feed rate under #21, press play:
The following user(s) said Thank You: tecno
6 years 4 months ago #171289 by tecno
Replied by tecno on topic Raspberry Pi 4 with PlasmaC
Time for me now to add plasmaC aseverything looks to be working OK.
Need to fix some mechanics, was a bit over optimistic re stepper motor fasteners.
But the concept works that i scrambled together and I am happy about that!
Big thanks to all cheering on my long way here.
The following user(s) said Thank You: tommylight, Clive S
6 years 4 months ago #171294 by tecno
Hmmmm
Did run the configurator, obviously with not all correct so I then did run configurator and tried reconfigure = here it stopped. So I can not get my errors correct. Bug?
6 years 4 months ago #171295 by tommylight
Make a new config with the configurator and delete the old one.
6 years 4 months ago #171296 by tecno
OK didn't think to solve it that way :)
Will play tomorrow time to get some sleep.
6 years 4 months ago #171367 by PCW
Replied by PCW on topic Raspberry Pi 4 with PlasmaC
Not sure why but I get quite a bit better latency:
Time to create page: 0.083 seconds
