Raspberry Pi 4 with PlasmaC
6 years 4 months ago #171369 by phillc54
That is better than mine as well, I get arund 100uS and there is not a great deal of diffrence between isolcpus=1,2,3 or isolcpus=2,3. There does appear to be slightly better graphic performanc with isolcpus=2,3
cmdline.txt is:
console=serial0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait lapic noxsave acpi_osi= isolcpus=2,3 idle=poll acpi_irq_nobalance noirqbalance vmalloc=32MB clocksource=acpi_pm net.ifnames=0
config.txt has:
[pi4] # Enable DRM VC4 V3D driver on top of the dispmanx display stack dtoverlay=vc4-fkms-v3d max_framebuffers=2 kernel=kernel7l-rt.img force_turbo=1 dtoverlay=disable-bt
I am running headless over wifi, I wonder if that makes a difference.
6 years 4 months ago #171378 by tecno
Replied by tecno on topic Raspberry Pi 4 with PlasmaC
Headless here too.
Anywho I seems to be stable with no error messages.
The following user(s) said Thank You: bbsr_5a
6 years 4 months ago #171387 by bbsr_5a
Replied by bbsr_5a on topic Raspberry Pi 4 with PlasmaC
did you go with the above settings on the same kernel
6 years 4 months ago #171389 by tecno
Yes
6 years 4 months ago #171396 by tecno
Is it mode 2 in plasmaC when I have Tchad 300
6 years 4 months ago #171400 by phillc54
If your plasma machine has arc ok or similar use mode 1 otherwise use mode 0.
Mode 2 is for external THC like a Prima or similar.
The following user(s) said Thank You: tecno
Time to create page: 0.238 seconds
