Raspberry Pi 4 with PlasmaC
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
27 May 2020 07:10 #169043 by phillc54
Raspberry Pi 4 with PlasmaC was created by phillc54
I had a bit of a play with a Pi4 today.
It is running Debian Buster with LinuxCNC 2.8 from the Buildbot and using a Mesa 7i96.
Dry run testing worked well then I tried a real cut but about half way through I got a strange error from hm2_eth (I think, in my rush I forgot to write it down :blush: )
I then changed the servo period to 2000000nS and proceeded to do about 20 odd cuts without fail and PlasmaC seemed to perform well at that slow rate.
I will play a more but so far it looks like a reasonable prospect.
The following user(s) said Thank You: tommylight, Franklin
27 May 2020 09:32 #169080 by jay1st
Replied by jay1st on topic Raspberry Pi 4 with PlasmaC
Nice to read that !
Is it a full stand alone system with it's own screen or remote from a computer ?
  • phillc54
  • Platinum Member
  • Platinum Member
27 May 2020 09:35 #169083 by phillc54
Replied by phillc54 on topic Raspberry Pi 4 with PlasmaC
At this stage I am SSHing into it. If it proves to be worthwhile I might make a GUI for a small touch screen.
27 May 2020 09:42 #169089 by jay1st
Nice !!!!!!!! cant wait for it !!!
27 May 2020 09:54 #169092 by rodw
Replied by rodw on topic Raspberry Pi 4 with PlasmaC
Using Windows Terminal Services client (MSTSC) is also very usable acessing a raspberry 3 if you install a RDP client. I've got a couple here with PoE hats to power them...
27 May 2020 09:59 #169094 by rodw
Ooops, I forgot Phill is a Mac man. I'll let you translate MSTSC to mac speak. I am a Chromebook convert myself!
  • phillc54
  • Platinum Member
  • Platinum Member
27 May 2020 10:10 #169099 by phillc54
I could use Screen Sharing on the Mac which gets me into all my other Linux boxes using VNC except the Pi which uses RealVNC and won't connect. I may change it out for one of the other VNCs that do work but SSH is good enough for testing, it looks neater too.
27 May 2020 10:12 #169101 by rodw
Pretty sure I installed XRDP in the Pi. It just worked.
27 May 2020 10:12 #169102 by Mike_Eitel
Replied by Mike_Eitel on topic Raspberry Pi 4 with PlasmaC
I use xrdp quite often on different kind of systems. On start you have a dropdown choice of clients. Never did it but might run with mac too.
Mike
27 May 2020 10:26 #169108 by tommylight
Replied by tommylight on topic Raspberry Pi 4 with PlasmaC
:ohmy: Did you just mention windoze on a Linux forum ??? :S
Time to create page: 0.187 seconds
