Raspberry Pi 4 with PlasmaC
10 Jun 2020 03:43 #170926 by tecno
Replied by tecno on topic Raspberry Pi 4 with PlasmaC
So under [pi4] I tried to comment out but then it would not start color splash
I have a feeling all this is a graphics problem.
My setup is µHDMI to normal HDMI/VGA adapter to VGA display.
That chain works with *normal* Buster.
I will soon be out a couple of hours, need my feet to be taken care of chiropody
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
10 Jun 2020 03:53 #170927 by phillc54
Replied by phillc54 on topic Raspberry Pi 4 with PlasmaC
I have run that image headless and also with a cheap HDMI monitor
10 Jun 2020 04:13 #170930 by tecno
Tried all graphics related settings in config.txt
It makes one a bit puzzled, the only diff is that you have 2GB version and I have the 4GB and that should not make any difference.
10 Jun 2020 04:52 #170934 by alkabal
Replied by alkabal on topic Raspberry Pi 4 with PlasmaC
I have use the image with rpi4 4go + waveshare 13" hdmi touchscreen + 2 sd card and start fine with mate desktop without changing anithing.
Is you rpi have enough power ?
www.raspberrypi.org/forums/viewtopic.php?f=28&t=243886
raspberry-pi.fr/hdmi-raspberry-pi-marche-pas-solution/
  • phillc54
  • Platinum Member
  • Platinum Member
10 Jun 2020 04:55 - 10 Jun 2020 05:18 #170936 by phillc54
I am thinking of getting a touchscreen, headless on LinuxCNC is a little bit clunky. What do you think of the waveshare that you have?
EDIT: What resolution is it?
Last edit: 10 Jun 2020 05:18 by phillc54.
10 Jun 2020 05:15 #170938 by tecno
I have a 3A PSU
  • phillc54
  • Platinum Member
  • Platinum Member
10 Jun 2020 05:18 #170939 by phillc54
I did my testing on an official 3A PSU from Raspberry, it is currently running on a 3A MeanWell PSU.
10 Jun 2020 05:25 - 10 Jun 2020 05:30 #170940 by alkabal
I'm really happy with this screen from 2 years.
(have some problem at first attempt with a dead board and after that with a updated board that does not work with Beaglebone hdmi non standard detection but seller send me 2 time replacement boards and help debugging greatly)
I thinks now is better to use a 15" but except that this screen work fine ! (including hdmi audio)
The touchscreen work better with RPI original DM (openbox) than mate (i can't click on the different menu from task bar.
I never found a correct configuration for use multitouch or twofing for some right click.
The goal is now to print a case for fit all in one RPI/screen/keyboard and have a easily removable panel with only ethernet and power to unplug for sharing with other machine.
Resolution is fiull HD 1920x1080
Last edit: 10 Jun 2020 05:30 by alkabal.
10 Jun 2020 10:10 #170967 by tecno
I am back to you last image of today. buster-rt.img
pi@pi4-mate:~ $ uname -a
Linux pi4-mate 4.19.71-rt24-v7lrt+ #1 SMP PREEMPT RT Mon May 18 16:17:58 AE20 armv7l GNU/Linux
This I get via PUTTY so it is booting but I get no graphics. Did run raspi-config just to assure VNC is enabled but no contact.
10 Jun 2020 10:18 #170969 by tecno
H O L D T H E P R E S S E S
I changed PSU earlier today and just now I just tested to move the HDMI connector closer to the 5V input and
VOILA
Time to create page: 0.539 seconds
