Raspberry Pi 4 with PlasmaC
20 Oct 2022 17:22 #254634 by rdtsc
Replied by rdtsc on topic Raspberry Pi 4 with PlasmaC
Hi. Is there any news to report on this? Currently tinkering with 2.9.0_pre0 on RaspiOS Bullseye aarch64 5.19.15-rt10-v8+ #1 SMP PREEMPT_RT.
21 Oct 2022 04:18 - 21 Oct 2022 04:19 #254658 by elovalvo
Replied by elovalvo on topic Raspberry Pi 4 with PlasmaC
At this link
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=150#253623
is available a new image with 2.9.0_pre0 on RaspiOS Bullseye based on
Linux raspberrypi 5.15.65-rt49-v8+ #1 SMP PREEMPT_RT Tue Sep 6 18:12:35 BST 2022 aarch64 GNU/Linux
Last edit: 21 Oct 2022 04:19 by elovalvo.
The following user(s) said Thank You: phillc54, rdtsc
28 Oct 2022 19:18 - 29 Oct 2022 11:17 #255362 by rdtsc
Just a note, for those new to this... RPI imager will not burn this to a TF (micro SD) card successfully. Use Balena Etcher on the extracted .img file. That will work.
Looks good!  Much further than I was getting with manual builds of everything.  Thank you. :)
Note, pncconf was giving locale errors, so had to do:
export LC_ALL="en_US.UTF-8" & export LC_CTYPE="en_US.UTF-8" & sudo dpkg-reconfigure locales
en_US was marked and es_US was removed.  When complete, close (in my case kill pncconf) and try again and it works.
Last edit: 29 Oct 2022 11:17 by rdtsc. Reason: Adding caveats as they are encountered.
Time to create page: 0.193 seconds
