Raspberry Pi 4 with PlasmaC
- Mike_Eitel
- Thank you received: 183
05 Jun 2020 07:02 #170244
by Mike_Eitel
Replied by Mike_Eitel on topic Raspberry Pi 4 with PlasmaC
I do not know if you have seen already how to prepare pi4 for ssd.
- tecno
- Thank you received: 127
05 Jun 2020 08:38 #170253
by tecno
Replied by tecno on topic Raspberry Pi 4 with PlasmaC
I have no SSD only 2.5" HDD and it will have to do for now.
Trying to setup RPi headless output via VNC on my tablet with 1280x800 but I can not find the correct settings in RPi to get full Gmoccapy on the tablet.
Any hints on how to get this working is much appreciated.
- tecno
05 Jun 2020 09:33 #170259
by tecno
I have managed to get display resolution fixed so now almost the whole screen of Gmoccapy is there.
- tecno
05 Jun 2020 11:12 #170264
by tecno
Obviously not my friend this RPi4 is
- phillc54
- Thank you received: 2100
05 Jun 2020 19:28 #170304
by phillc54
Replied by phillc54 on topic Raspberry Pi 4 with PlasmaC
I think I set mine in /boot/config.txt
HDMI modes are here www.raspberrypi.org/documentation/config.../config-txt/video.md
hdmi_group=2
# 1680 x 1050
hdmi_mode=58HDMI modes are here www.raspberrypi.org/documentation/config.../config-txt/video.md
- tecno
06 Jun 2020 03:49 #170325
by tecno
A good night sleep and one old fart can tinker better
Config.txt = 27
and
change Display setting in RPi menu to 1200x800 and all is well.
I was close yesterday with a bit of overscan that bothered me.
So now I will copy my test settings from my PC and hopefully I can get all axis to move, that is the first goal then add IO.
Cheers from Sweden on our National Day
Config.txt = 27
and
- Mike_Eitel
06 Jun 2020 07:32 #170359
by Mike_Eitel
Hi tecno
You can get a pi4 ssd for low budged around 20-25$ fx wd-green ones.
I would propose you to go that road as soon you have prooven pi4 bbeing your solution.
Mike
One of the nice comparisons
Mike
The following user(s) said Thank You: tecno
- tecno
08 Jun 2020 07:46 #170634
by tecno
I am having problems with my Ri4
forum.linuxcnc.org/38-general-linuxcnc-q...s-ok?start=10#170630
forum.linuxcnc.org/38-general-linuxcnc-q...s-ok?start=10#170617
What have you guys done to get a good latency?
- tecno
08 Jun 2020 08:22 #170637
by tecno
I added isolcpus = 1,2,3
But I stll get hm2/hm2_7i96.0: error finishing read
- Thank you received: 5336
08 Jun 2020 08:44 #170641
Looks like you are not running a real time kernel...
Replied by PCW on topic Raspberry Pi 4 with PlasmaC
Time to create page: 0.320 seconds
