Raspberry Pi 4 with PlasmaC
02 Jun 2020 12:47 #169839 by rodw
Replied by rodw on topic Raspberry Pi 4 with PlasmaC
It would have to here. I'm sure they don't even sell an 8gb one here. I only use 4gb on my J1900 and I was told to just get 2gb at the time..
02 Jun 2020 12:50 #169840 by tecno
Replied by tecno on topic Raspberry Pi 4 with PlasmaC
So 4GB it is = low budget ;) I assume it will work in my plasma rig, I want to use a laptop for remote via VNC or whatever is best suited for the job.
02 Jun 2020 12:56 #169843 by rodw
Yeh, I found the new Pi quite usable from the Windows remote desktop with XRDP installed on the PI. I've got a couple and one is tucked away in the cupboard that houses my network stuff and powered by PoE.
02 Jun 2020 12:59 #169844 by tommylight
Replied by tommylight on topic Raspberry Pi 4 with PlasmaC
So you think 4GB willl be OK even in close future with 64bit OS?
I am using 64bit Linux Mint with XCFE on a single processor laptop with only 1GB of memory. It runs the machine all day long without a single issue.
But editing stuff on it takes a while ! :)
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Jun 2020 18:13 #169884 by phillc54
Replied by phillc54 on topic Raspberry Pi 4 with PlasmaC
The Pi4 I am testing with is 2Gb
04 Jun 2020 12:18 #170106 by tecno
So my friends, I now have RPI4 with 4GB up and running with latest Buster. Also *boot* via 2.5" HDD and VNC remote is working.
So what packages do I need to download to get PlasmaC up and running?
04 Jun 2020 12:59 #170111 by tommylight
04 Jun 2020 13:50 #170117 by tecno
Is this the latest 2.9 ?
buildbot.linuxcnc.org/dists/buster/maste...g64994a259_armhf.deb
So how do I install (used to iso's ;) )
04 Jun 2020 18:16 #170167 by tommylight
Sorry for the late reply, had guests.
Yes that is it, double clicking on it should open gdebi so just clicking on install should do.
If there is no gdebi:
sudo apt-get install gdebi
If it complains about dependency not satisfiable, enable the repositories in software sources.
Try again.
The following user(s) said Thank You: tecno
05 Jun 2020 04:52 #170226 by tecno
Thanks, no gdebi now installed the deb package.
But... this morning NO HDD boot but a lot of ext4 errors and no VNC.
Back to SD and all is well.
Time to create page: 0.181 seconds
