- Thank you received: 2100
Feature Request
I was interested to see if it would happen, as it has not been reported before. (that I can remember)snowgoer540 wrote:
Oh, testing me to see if I would notice are you?!phillc54 wrote: That is the same as the X/Y "jiggle", you are jogging back up to the soft limit. I purposely dodn't disable the offsets on Z like I did with X/Y to see if this would appear. I am surprised that it took so long to find. I will do the same with Z, disable offsets unless they are being used.
You get to keep your job. :laugh:What do I win now??
Now I know why I said somewhere in the docs to not jog the Z axis.I may not have noticed had I not accidentally started a probe with the torch lowered. Normally I don't jog the Z axis much after a failure.
It is not a bug, it is the way external offsets works. It is mentioned in the external offsets docs to stay away from the soft limits while offsets are active.Regarding the offset, I think we said this was a bug in the LinuxCNC core? If so, did it ever get reported?
- snowgoer540
- Topic Author
- Thank you received: 907
I do remember trying to get it to happen with the Z axis, but I never could. *shrug* guess I had a stroke of brilliance today? lolphillc54 wrote: I was interested to see if it would happen, as it has not been reported before. (that I can remember)
Sweet! I enjoy it.You get to keep your job. :laugh:
haha, I did say it was an accident :laugh: at least when someone else makes the mistake it wont do a springy maneuver haha.Now I know why I said somewhere in the docs to not jog the Z axis.
It is not a bug, it is the way external offsets works. It is mentioned in the external offsets docs to stay away from the soft limits while offsets are active.[/quote]Regarding the offset, I think we said this was a bug in the LinuxCNC core? If so, did it ever get reported?
OHH, I missed that part. Ok sounds good then. Just making sure.
- snowgoer540
- Topic Author
phillc54 wrote: All these issues "should" be fixed now in 2.8, master and the test branch.
Thanks Phill, much appreciated as always! I am planning to mess with my THC this evening so I'll report back if something is amiss
- snowgoer540
- Topic Author
