THC Velocity lock and void lock
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
08 Sep 2020 17:03 #181301 by mariusl
THC Velocity lock and void lock was created by mariusl
Can someone please elaborate for me on the THC Velocity lock and the Void lock. How do they think and how do I control their behavior?
Regards
Marius
www.bluearccnc.com
08 Sep 2020 20:23 #181316 by tommylight
Replied by tommylight on topic THC Velocity lock and void lock
THC Velocity lock = lock the THC if the feed rate during cutting goes below a set point, normally happens on corners when the velocity has to be lowered to keep with the acceleration constraints. Can be set in the GUI as a percentage of the feed rate.
Void lock = lock the THC if the voltage goes up very quickly during cutting inside a preset time period, normally happens when crossing a previously cut line on the material. This is done to prevent the torch going to low and hitting the material.
The following user(s) said Thank You: mariusl
  • mariusl
  • Platinum Member
  • Platinum Member
08 Sep 2020 20:58 #181320 by mariusl
Replied by mariusl on topic THC Velocity lock and void lock
Thanks Tommy, I think I have it. My problem must be with Void lock as I dont recall setting any parameters for that but the option is on.
Regards
Marius
www.bluearccnc.com
08 Sep 2020 21:16 #181323 by rodw
Replied by rodw on topic THC Velocity lock and void lock
I think the void lock is still a work in progress. Its a method to disable the THC when a massive and rapid spike in voltage occurs when the torch crosses a void.
I've got close but have not revisited it for a long time. Generally, good part design and nesting avoids the issue so it sounds good in theory but is protecting against a condition that rarely occurs in practice.
08 Sep 2020 23:21 #181334 by phillc54
Replied by phillc54 on topic THC Velocity lock and void lock
Void lock was working for me at default values last time I tested it. If you want to disable it then uncheck the checkbox and save the parameters.
  • mariusl
  • Platinum Member
  • Platinum Member
09 Sep 2020 06:36 #181373 by mariusl
I agree, one should take care in nesting the parts. I don't think the system should correct bad job creation. Although it could come in handy if a straight cut is made to clean up remainder material.
Regards
Marius
www.bluearccnc.com
09 Sep 2020 07:16 #181384 by rodw
Yes sheet severing and cutting a hole in heavy plate when the slug drops away are the two use cases I want it for.
  • mariusl
  • Platinum Member
  • Platinum Member
09 Sep 2020 10:53 #181410 by mariusl
Especially if you are using lead ins and outs. The slug drops before the lead out cut is complete and causes the ARC_OK signal to be dropped.
Regards
Marius
www.bluearccnc.com
  • mariusl
  • Platinum Member
  • Platinum Member
17 Sep 2020 12:08 #182533 by mariusl
Just been talking to a customer and realized that there is a very important use for Void Lock. It is used when one does chain cutting on a job and it is not always possible to route the cut path to miss a previous kerf.
Please keep this feature!!
Regards
Marius
www.bluearccnc.com
17 Sep 2020 12:11 #182534 by tommylight
I am pretty sure it is staying there, just did not have the chance to give it a thorough test and report back to Phill .
Time to create page: 0.292 seconds
