THC Velocity lock and void lock
- phillc54
- Thank you received: 2100
14 Jul 2021 11:31 #214722
by phillc54
Replied by phillc54 on topic THC Velocity lock and void lock
- Thank you received: 4150
14 Jul 2021 11:37 #214724
Replied by rodw on topic THC Velocity lock and void lock
Agree its appalling. I did search and it could be related to a config error by our admins.
- snowgoer540
- Thank you received: 907
14 Jul 2021 14:00 #214740
by snowgoer540
Replied by snowgoer540 on topic THC Velocity lock and void lock
+10000 on the new editor comments. It's borderline unusable, certainly to edit a post, or even break up quoting.
I might recommend any suggestions that might even possibly help fix it be posted here: forum.linuxcnc.org/36-using-this-forum-q...itor?start=10#213150
That thread at least had JT's attention.
I try not to complain too hard about it, since it is free after all, but I do wish we could go back to when email was broken instead
- grijalvap
- Thank you received: 63
14 Jul 2021 15:45 - 14 Jul 2021 16:08 #214758
by grijalvap
Replied by grijalvap on topic THC Velocity lock and void lock
this is what I did on the old THCSM.comp attempt to solve the kerf crossing as you can see it does not take in to acount the speed or thickness
Now I see it should be included.
Regarding the picture that RODW posted with the dip after the bump, I recall similar images, and I recall that my thinking was, look for the slope and follow the sequence:
set the lock at the first raising slope then unlock only on the next raising after one falling slope(never try),
I will try this this weekend.
Last edit: 14 Jul 2021 16:08 by grijalvap.
14 Jul 2021 20:50 #214775
Pedro, please check your gmail account. I sent you some material.
The loopless averaging algorithm which should be called on each pass through the component is:note numreadings is a global variable set by a pin that sets the number of values to average from 3 to 1000. I used 100. If the buffer is not full, the average is based on the number read so far.
pin in s32 num_readings = 100 "Number of readings for average volts (3-1000)";
#define BUFSIZE 1000 // maximum number of readings to average torch volts
double buf[BUFSIZE];
int reading_count;
float avgarcvolts(double tvolts, int iscutting, int buffersize)
// Calculates the moving average of buffersize readings
static double *b = &buf[0], *p = &buf[0]; // pointers for beginning of buffer and current position
static double *e; // pointer for end of buffer
static int wascutting = 0; // cutting state last time
static double sumvolts = 0.0; // Sum of readings in buffer
static int numreadings = 0; // number of readings in buffer
static int last_thc_active = 0; // Save last state
e = &buf[buffersize]; // Initialise end pointer
if(!iscutting && wascutting){
// Torch just turned off, so reset the variables
p = b;
sumvolts = 0.0;
numreadings = 0;
wascutting = iscutting; //and save the state
return(0.0);
if(iscutting){ // Arc_OK is on so lets start gathering data to average
*p++ = tvolts; // Save volts to the buffer and increment pointer
if(numreadings < buffersize)
numreadings++;
if(p > e) // if we've gone past the end of the buffer, wrap to the beginning
p = b;
sumvolts += tvolts; // add the new reading
if(numreadings >= buffersize)
sumvolts -= *p; // subtract the oldest reading (which is the one we are pointing at now)
if(numreadings)
return(sumvolts/(double)numreadings); // return Average volts
else
return (0.0); // catch divide by zero errors
}Please Log in or Create an account to join the conversation.
14 Jul 2021 20:56 #214776
My current void lock code looks like this using the procedure shared earlier
AND yes I agree with Pedro, you need to follow the states to enable the THC again. My code does that but its a bit obfuscated..The easy bit is turning it off!
// Lets average the arc volts
avgvolts = avgarcvolts(tvolts, (int)arcokin, (int)reading_count);
average_volts = avgvolts;
torch_volts = tvolts;
dvdt = (tvolts - avgvolts)/fperiod; // Calculate change in volts for this servo cycle.
if(!thc_is_active)
void_hold = 0;
movingup = (last_dvdt <= dvdt ? 1:0); // set flag if volts are moving up
movingdown = (last_dvdt > dvdt ? 1:0); // set flag if volts are moving down
if(movingup && dvdt > dvdt_threshold && !void_hold && thc_is_active){
first_dvdt = dvdt; // record the level the dvdt was at when activated
trigger_volts = torch_volts; // and save the trigger volts
void_hold = 1; // hold the THC
else if(!gone_low && void_hold && (dvdt < (0.0 - dvdt_threshold)) && thc_is_active){
gone_low = 1;
else if(void_hold && gone_low && torch_volts <= trigger_volts && thc_is_active){ // holding and on our way up
void_hold = 0;
first_dvdt = 0.0;
trigger_volts = 0.0;
gone_low = 0;
last_dvdt = dvdt; // Save the last dvdt AND yes I agree with Pedro, you need to follow the states to enable the THC again. My code does that but its a bit obfuscated..The easy bit is turning it off!
14 Jul 2021 21:05 #214777
The states I identified for use in s a switch statement areVOID_LOW is when the DV/DT has fallen below the trigger point
VOID_END is when the DV/DT has risen back to our cutting zone and THC can be enabled
typedef enum { WAIITNG, THC_ACTIVE, VOID_FOUND, VOID_LOW, VOID_END} State_V;
State_V vstate = WAITING;VOID_END is when the DV/DT has risen back to our cutting zone and THC can be enabled
- grijalvap
14 Jul 2021 21:07 #214778
by grijalvap
Good, Thanks for the loop less average function, now I thinking to implement as component and use the enable disable input of PlasmaC to test and validate the code and after that maybe we can include code to PlasmaC.
thanks
thanks
14 Jul 2021 21:14 #214779
The state machine looks something like this (bugs and all)
Yes that was always my intention but an alternative I thought would be to add a second THC disable pin for user expansion so this could be added by a user easilly without breaking the plasmac config.Good, Thanks for the loop less average function, now I thinking to implement as component and use the enable disable input of PlasmaC to test and validate the code and after that maybe we can include code to PlasmaC.
thanks
if(torch_on){
//movingup = (last_dvdt <= dvdt ? 1:0); // set flag if volts are moving up
switch(vstate){
case WAIITNG:
if(thc_is_active){
vstate = THC_ACTIVE;
else{
break;
case THC_ACTIVE:
//if(movingup && dvdt > dvdt_threshold)
if(dvdt > dvdt_threshold){
first_dvdt = dvdt;
void_hold = 1;
vstate = VOID_FOUND;
break;
case VOID_FOUND:
if(dvdt < (0.0 - dvdt_threshold)){
vstate = VOID_LOW;
else{
break;
case VOID_LOW:
if(torch_volts <= trigger_volts){
elapsed_time += fperiod;
if(elapsed_time >= final_delay){
void_hold = 0;
first_dvdt = 0.0;
gone_low = 0;
elapsed_time = 0.0;
vstate = VOID_END;
break;
case VOID_END:
if(thc_is_active){
else{
vstate = WAITING;
break;
else{
void_hold = 0;
first_dvdt = 0.0;
gone_low = 0;
elapsed_time = 0.0;
vstate = VOID_END;
last_dvdt = dvdt; // Save the last dvdt Please Log in or Create an account to join the conversation.
- phillc54
14 Jul 2021 23:23 #214784
by phillc54
It would be nice if someone could post a few halscope plots cutting different thickness materials with THC disabled and crossing a kerf showing current velocity and arc voltage.
Time to create page: 0.455 seconds
