Camera For Touchoff
- Mike_Eitel
- Thank you received: 183
17 Sep 2020 09:28 #182523
by Mike_Eitel
Replied by Mike_Eitel on topic Camera For Touchoff
Rodw
It's fun.
Tried when was 40'ish. No successful
But i did it!
Happy about.
Mike
It's fun.
But i did it!
Happy about.
Mike
- Thank you received: 4149
17 Sep 2020 10:31 #182524
x 2
Replied by rodw on topic Camera For Touchoff
Rodw
It's fun.
But i did it!
Happy about.
Mike
x 2
- snowgoer540
- Thank you received: 907
17 Sep 2020 10:59 #182525
by snowgoer540
Replied by snowgoer540 on topic Camera For Touchoff
This is pretty cool! I have one of those cameras that I've never found to be useful as an endoscope. I may have to give this a go!
- Online
- Thank you received: 7480
17 Sep 2020 11:47 #182528
Replied by tommylight on topic Camera For Touchoff
Very nice, indeed.
Thank you.
Thank you.
- phillc54
- Thank you received: 2100
18 Sep 2020 07:05 #182614
by phillc54
Replied by phillc54 on topic Camera For Touchoff
@Rod
How does this look?
The video is a bit sketchy but it should give you an idea of how it works, the inital edge mark can be on either the X axis edge or the Y axis edge.
Don't pay too much attention to the accuracy, my camera is at a bit of an odd angle due to the masking tape mounting "bracket".
How does this look?
The following user(s) said Thank You: tommylight, partec, rodw, Franklin, snowgoer540
18 Sep 2020 08:06 #182617
Phill, Looks great. I think when you mark x0,y0 it should also set the origin so it becomes a 2 step process rather than 3. You will also need a button to clear the rotation (maybe you have that somewhere.).
- phillc54
18 Sep 2020 08:13 #182618
by phillc54
It is not touchscreen friendly, it uses the existing qtvcp camview widget with a custom handler file hack and I wanted to keep it compatible with the original way it is used but I may change that.
For mouse/touchpad users the button instructions are in the first post.
18 Sep 2020 08:15 #182619
- phillc54
18 Sep 2020 08:25 #182620
by phillc54
Yep, no worries.
It is interesting that this is not touchscreen friendly but it is one of the few things I have done that works better into Gmoccapy than Axis. Unfortunately iin Axis it doesn't fill the tab. Another questions for Chris...
18 Sep 2020 08:30 #182621
The Gmoccappy macros are quite good I have found. I think you can get it to ask you to enter values too. I just don't enjoy programming stuff like that in gcode.
Time to create page: 0.667 seconds
