Camera For Touchoff
- phillc54
- Thank you received: 2100
20 Sep 2020 21:22 #183025
by phillc54
Replied by phillc54 on topic Camera For Touchoff
Now that sounds like a plan. Hmmm the sun is over the yard arm, time for whiskey.
I don't think Victorians even drink Fosters do they?
You make me laugh. I'm giving up beer and drinking whiskey from here on!
- Franklin
- Thank you received: 19
21 Sep 2020 06:45 #183120
by Franklin
Replied by Franklin on topic Camera For Touchoff
Phill, you are a magician!
I wonder, if the auto edge detection that Rod reminded about might work as the scan function like Scanything?
Often the customer asks to make a duplicate of his part, and it would be great to draw the outline the object on paper and scan it on a plasma machine.
The following user(s) said Thank You: aleksamc, Methier
- web123456
29 Sep 2020 15:12 - 29 Sep 2020 15:15 #184324
by web123456
Replied by web123456 on topic Camera For Touchoff
Hello ! tell me how to install on LinuxCNC 2.9.0 Debian 7 Wheezy RTAI Camera For Touchoff .Embeded tab command "halcmd loadusr -Wn camera qtvcp -c camera -x 67109040 cam_align" exited with error: 1
task: 130 cycles, min=0.000249, max=0.058097, avg=0.009465, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Last edit: 29 Sep 2020 15:15 by web123456.
- phillc54
29 Sep 2020 18:10 #184336
by phillc54
- Thank you received: 2182
30 Sep 2020 00:35 #184352
Replied by cmorley on topic Camera For Touchoff
Try:
halcmd loadusr -Wn qtvcp_embed qtvcp -d -c qtvcp_embed -x {XID} cam_align
- partec
- Thank you received: 27
08 Aug 2021 02:13 #217184
by partec
Replied by partec on topic Camera For Touchoff
as phillc54's cam_align_handler.py named ..._2020-09-18.py still works fine in buster LCNC 2.8.0 there it does not work anymore in buster LCNC 2.8.2
- phillc54
08 Aug 2021 02:27 - 08 Aug 2021 02:29 #217186
by phillc54
I haven't looked at this code for a long time...
The error is here:
I cannot see that piece of code in the file posted here whcih I think is the latest:
forum.linuxcnc.org/plasmac/40057-camera-...choff?start=0#182507
Are you sure this is what you are using?
The error is here:
File "/home/eruepe/linuxcnc/configs/PAR_ISEL/cam_align_handler.py", line 88, in nextFrame
self.pin_.set(360 - self.w.camview.rotation)
AttributeError: HandlerClass instance has no attribute 'pin_'I cannot see that piece of code in the file posted here whcih I think is the latest:
Last edit: 08 Aug 2021 02:29 by phillc54.
The following user(s) said Thank You: partec
- partec
08 Aug 2021 02:57 #217190
by partec
thank you so much - just now, when I test with your named cam_align_handler.py file here, this loads and works in LCNC 2.8.2 as expected!
- partec
08 Aug 2021 03:22 #217192
by partec
Phill, may I ask, can you just publish the appropriate cam_align.ui file here, please?
- phillc54
08 Aug 2021 03:24 - 08 Aug 2021 03:34 #217193
by phillc54
The one in my previous post is the latest as far as I know.
Edit:
I think I misunderstood, you wanted the .ui file.
It doesn't use a .ui file, it uses the standard QtVCP camview widget. the source is here:
github.com/LinuxCNC/linuxcnc/blob/2.8/li...ts/camview_widget.py
Edit:
Last edit: 08 Aug 2021 03:34 by phillc54.
