Nan - voltage
6 years 1 month ago - 6 years 1 month ago #183086 by Tesremos
Replied by Tesremos on topic Nan - voltage
Interesting.
the difference i see is "new"plasmac.comp == -0 for volts.
old plascmas.comp == 0 for volts
20/20 with old plasmac (just installed) no nan.
ill poke the low pass again to 25 n see if it Nan's on me :)
edit: second opening with lowpass 25 == Nan
Last edit: 6 years 1 month ago by Tesremos.
6 years 1 month ago - 6 years 1 month ago #183087 by phillc54
Replied by phillc54 on topic Nan - voltage
Some time back a few guys said they didn't like the -0 so I made anything between 0 and -0.5 read as 0. It has to do with how floating numbers are displayed.
It is possible to fine tune the Offset so it doesn't go below 0.
You posted the edit while I was typing...
Last edit: 6 years 1 month ago by phillc54.
6 years 1 month ago #183089 by rodw
Replied by rodw on topic Nan - voltage
There is something I have read somewhere about a bug generating a nan in a NML message. Maybe it was somewhere here. read on a bit.
forum.linuxcnc.org/41-guis/36920-labview...cnc?start=100#182307
6 years 1 month ago - 6 years 1 month ago #183090 by Tesremos
dosent bother me what is displays :) it could be -500,000,000 if it still performs as expected its fine :)
okay, so lowpass = 0 results in, 0 instances of nan
but lowpass (for me) stops crazy reactions to tiny variances in voltage.
whata i do?
machine at the moment, if it dosent load with a nan, runs PERFECT.
but it'd be nice if i could open the machine, and every time 100% be confindent that someone else running the machine wont run into a Nan.
6 years 1 month ago #183091 by phillc54
Tesremos wrote: but lowpass (for me) stops crazy reactions to tiny variances in voltage.
Have you tried with a higher lowpass frequency?
You can change the value using setp while it is running .
6 years 1 month ago #183093 by phillc54
rodw wrote: There is something I have read somewhere about a bug generating a nan in a NML message. Maybe it was somewhere here. read on a bit.
The test comps I posted ensure all inputs were not nan and yet the output still created a nan.
The thing is I cannot get it misbehave here
Time to create page: 0.154 seconds
