Nan - voltage
6 years 1 month ago - 6 years 1 month ago #183257 by Tesremos
Replied by Tesremos on topic Nan - voltage
lowpass = 0 results in 0 instances of nan 20/20 tests
lowpass = 25 results in nan 11/20 tests
lowpass = 50 results in lowpass 13/20 tests
edit :
Warning: Spoiler! [ Click to hide ]
You do not have permissions to access this page.
Last edit: 6 years 1 month ago by Tesremos.
6 years 1 month ago - 6 years 1 month ago #183258 by phillc54
Replied by phillc54 on topic Nan - voltage
This one should give an error message with some values when it first sees a nan, hopefully it will point us in the right direction.
Edit: Oops, I missed a variable. I replaced the file...
Last edit: 6 years 1 month ago by phillc54.
6 years 1 month ago #183266 by Tesremos
no worries, il give it a go as soon as i get to the shop tommorrow :)
thank you phill.
6 years 1 month ago #183267 by phillc54
I'm sure we'll get there eventually.
I made a Stretch VM today to match your machine and built master branch to the same commit version you have and still can't get a single nan so it's all guesswork on my part.
6 years 1 month ago - 6 years 1 month ago #183391 by Tesremos
here is your generated error :)
edit: and now i know how to screenshot!!! winning
6 years 1 month ago - 6 years 1 month ago #183392 by rodw
Replied by rodw on topic Nan - voltage
Tesremos wrote: here is your generated error :)
So clearly as I suspected, and mentioned before, the calibration values in the GUI are not making it to plasmac.comp.
The simplest workaround is to configure Plasmac in hal. Try something like this in your postgui.hal file
unlinkp plasmac.arc-voltage-offset unlinkp plasmac.arc-voltage-scale setp plasmac.arc-voltage-offset <your_offset_value> setp plasmac.arc-voltage-scale <your_scale_value>
EDIT: There is no need at all to have these values in the GUI as once set up, they never need changing. I suggest taking those values out and using some INI file settings to populate them (or a setp in my connections)
Last edit: 6 years 1 month ago by rodw.
Time to create page: 0.174 seconds
