- Thank you received: 2100
I don't see how NML is used in any of this, all we do is set and get HAL pins.rodw wrote: Actually this might be better
unlinkp these plasmac.comp pins
Code:pin in float arc_voltage_offset "offset to set arc voltage to 0 at 0 volts"; pin in float arc_voltage_scale "scale to convert arc_voltage input to actual volts";
setp them to the values used in your gui.
This would take NML out of the equation as values are not set by gui variables.
If it still happens, then its most likely a plasmac bug and you have isolated that to the lowpass code.
PurduePete wrote: This issue seems to be only in 2.9. Not sure if that helps or not. When my machine was done, we stepped back to 2.8 to get rid of the issues (which was just a trial that didn't work). The nan issue disappeared.
