- Thank you received: 2100
I don't actually know what happened afterwards, all I knew about was the wrong display value. Maybe Tesremos will fill us in.rodw wrote: So does receiving a number as a nan break things forever? Shouldn't it sort out the output when a valid number is received from the encoder?
It seems to me thats what should happen, but that did not seem to be the case.
Both the display and all the plasmac comp calculations.rodw wrote:
So was it just the display value or was the arc voltage used by plasmac wrong too? You would not have thought you'd start cutting 1 second after turning the machine on.
