Nan - voltage
6 years 1 month ago #183421 by phillc54
Replied by phillc54 on topic Nan - voltage
Tesremos wrote: it crashes into stuff.
Now that is a good reason to fix it. :)
6 years 1 month ago #183422 by phillc54
rodw wrote: Sorry, just to be clear, WatchLoop in in that file.
Now I know where that message came from.
6 years 1 month ago #183425 by Tesremos
Replied by Tesremos on topic Nan - voltage
also, it dosent sort its self out..once it boots with a nan..
it stays nan until you reopen linuxcnc.
if u run with nan. it crashes.
or from memory. if mode 0.
never reaches arc okay. and dosent do anyrhing but pop a hole in stuff.
6 years 1 month ago #183426 by phillc54
Does it ever show a nan at some later stage or only on startup?
6 years 1 month ago #183429 by Tesremos
only ever on startup.
maaaayyybbeee once ive seen it "appear"
6 years 1 month ago - 6 years 1 month ago #183450 by Clive S
Replied by Clive S on topic Nan - voltage
phillc54 wrote: Does it ever show a nan at some later stage or only on startup?
Phill. Not sure this is relevant but recently I have been playing around with denounce like this:
setp scale.0.gain 60
setp lowpass.0.gain 1.000000
net spindle-velocity-feedback-rps => lowpass.0.in
net spindle-fb-filtered-rps lowpass.0.out => abs.0.in
net spindle-fb-filtered-abs-rps abs.0.out => scale.0.in
net spindle-fb-filtered-abs-rpm scale.0.out => pyvcp.spindle-speed
Using 2.8 on a P/port with lathe for spindle display from a 100 slot disk with opto's
That is I have seen nan in the display with some odd setting in the gain.
Last edit: 6 years 1 month ago by Clive S.
Time to create page: 0.226 seconds
