Nan - voltage
  • Moderator
  • Moderator
21 Sep 2020 13:11 - 21 Sep 2020 13:12 #183136 by tommylight
Replied by tommylight on topic Nan - voltage
Redundancy ?????
Last edit: 21 Sep 2020 13:12 by tommylight.
21 Sep 2020 13:15 #183139 by rodw
Replied by rodw on topic Nan - voltage
Actually this might be better
unlinkp these plasmac.comp pins
pin in  float   arc_voltage_offset          "offset to set arc voltage to 0 at 0 volts";
pin in  float   arc_voltage_scale           "scale to convert arc_voltage input to actual volts";
setp them to the values used in your gui.
This would take NML out of the equation as values are not set by gui variables.
If it still happens, then its most likely a plasmac bug and you have isolated that to the lowpass code.
21 Sep 2020 13:21 #183141 by phillc54
Replied by phillc54 on topic Nan - voltage
I don't see how NML is used in any of this, all we do is set and get HAL pins.
21 Sep 2020 13:31 #183143 by rodw
but you are setting hal pins via GUI variables so won't the GUI connect to HAL via NML?
I am trying to avoid that part of linuxcnc for now.
21 Sep 2020 21:06 #183183 by PurduePete
Replied by PurduePete on topic Nan - voltage
I'm a little late to the party. Was running a larger job and didnt take the time to post after Testremos mentioned he started a thread on it. Phillc54, this issue seems to be only in 2.9. Not sure if that helps or not. When my machine was done, we stepped back to 2.8 to get rid of the issues (which was just a trial that didn't work). The nan issue disappeared. I updated to 2.9 again for the FWD and REV buttons as they are very handy on larger runs. So it came right back. Also, dont remember if Tesremos had the nan issue in a virtual machine or not.
21 Sep 2020 21:14 #183184 by rodw
This issue seems to be only in 2.9. Not sure if that helps or not. When my machine was done, we stepped back to 2.8 to get rid of the issues (which was just a trial that didn't work). The nan issue disappeared.
So it does not seem to be a Plasmac Issue but instead a Linuxcnc bug. It could have something to do with the move to Python 3.0 on master perhaps.
  • Moderator
  • Moderator
21 Sep 2020 21:39 #183189 by tommylight
Very foggy on this, but i have seen this nan thing when i did an update of LinuxCNC but did not update the PlasmaC config, it was around .148 version i think, give or take a bit, and after updating the config everything was back to normal.
I use Master for everything.
21 Sep 2020 22:06 #183193 by PurduePete
We did not have issues when on v.144 or whatever. Just when we updated plasmac. But could be a problem with Linuxcnc.
21 Sep 2020 23:16 - 21 Sep 2020 23:17 #183199 by phillc54
I do all my testing on 2.8 so I guess I had better build a 2.9 machine.
Are you using Buildbot or Run In Place?
Edit: Fwd & Rev is in 2.8 as well.
Last edit: 21 Sep 2020 23:17 by phillc54.
22 Sep 2020 03:30 #183242 by phillc54
Here is the next test version of the comp.
Could anyone having this issue also please post the results of the following two terminal commands:
linuxcnc_info
dpkg -l 'libglib2*'
Time to create page: 0.235 seconds
