- Thank you received: 106
snowgoer540 wrote: Personally, I would hook the THCAD-10 to the 7i76e's encoder 5V supply...
rodw wrote: You can also use the 7i76e spindle relay but its polarised so if you connect it the wrong way, the torch will be always on..
Its working fine for me once I turned the wiring around the right way...
HINT: have the plasma turned off when you first fire it up. With a bit of luck your Hypertherm will sense a wiring error (torch stuck on) like my Thermal Dynamics, raise an error and not turn on.
Eliminates the relay so one less failure point... Took me a long time to try it, but it works fine for me! So with ohmic sensing I have no relays in my machine...
snowgoer540 wrote: Yep, in fact that’s how mine are wired.
