snowgoer540 wrote:
txtrone wrote:
snowgoer540 wrote:
This schematic is very similiar to the schematic in the the primer, to which I was referring. However, this one has a bit more detail and also an additional resistor. My original question could have been worded better. I was asking how exactly to wire the 390K resistor into the circuit, ie: do I simply solder a wire onto each end and attach them to +IN on THCAD5 and +24V on isolated power supply?
Your drawing clarifies the power rating of the 390k resistor at 1w, which was another question I had, so that is great!
It also has another resistor in the circuit, unlike the schematic in the manual, the 24k 5w. Is this a newer/updated schematic which has not yet been incorporated into the manual?
thx
Does this look correct? Depending on how my hypertherm pm85 reacts, I may need to swap the TB4-5/6 wires around like you stated earlier.rodw wrote: The spindle enable is on TB4-5 and TB4-6You'd have to check with halshow but there is a single pin to trigger this which ends in something like spinena
rodw wrote: When I added the resistor to mine I had to use 5 x 4.7k 1 W resistors in series as that was all I could buy locally. I soldered them to a board and placed a two terminal strip at each end that I tied together on the board. This made it super easy to wire it in.
www.digikey.com.au/product-detail/en/pho...8/277-1247-ND/260615
But today I would use a modified DIN rail terminal block to carry the correct resistor.
