Arc OK intermitent issues on torch fire
5 years 6 months ago #204534 by snowgoer540
Either one will work fine
The following user(s) said Thank You: txtrone
5 years 6 months ago #204535 by txtrone
snowgoer540 wrote: Either one will work fine
Thanks a ton! I am still confused about exactly where PCW was suggesting I fuse the isolated 24+ and torch sense cables a few post back... but I have plenty to do in the meantime. What size fuses did you use?
5 years 6 months ago #204583 by txtrone
PCW wrote: Also if the table and torch sense lines are long (THCAD and 24V PS not in plasma box) I would fuse them at the plasma source end.
PCW - As I was wiring the THC and Ohmic circuits this afternoon I was still puzzled by this post. Do you mean the fuses should be in the sense lines directly next to the THCAD5 and another directly next to the 24- post on the isolated PS? Or just the opposite of that, a fuse on the gantry near the torch and another on the table near the connection point of the sense?
Also, what size/type fuses would you recommend using?
Thanks again!
5 years 6 months ago #204584 by PCW
The fuses are to protect the sense wires from fault currents so they
should be as close to plasma machine as possible. 1A should be fine
(It should be rate to interrupt the plasma voltage and current)
5 years 6 months ago #204585 by txtrone
Thank you
5 years 6 months ago #204698 by txtrone
PCW wrote: The fuses are to protect the sense wires from fault currents so they
Would this FNQ-1 fuse be adequate?
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Time to create page: 0.329 seconds
