- Thank you received: 4153
rodw wrote: QTPlasmac supports the laser but I have not played with it on real hardware. Maybe over Easter.. But I don't have enough pins on the gantry to turn it on and off from the GUI
snowgoer540 wrote: Most of the circuits ive seen here totally negate fuses, breakers, etc. So I would consider
everything “use at your own risk, your mileage may vary, etc.” Whatever you do, please make sure you do it safely.
I have used it last two days, it works, but i have it on all the time, although it is wired to a pin on the 7i92 so i might change that.rodw wrote: QTPlasmac supports the laser but I have not played with it on real hardware. Maybe over Easter.. But I don't have enough pins on the gantry to turn it on and off from the GUI
That is a great point! Do you have schematics of your system that you would be willing to share?
Besides the breakers on either side of my power supplies I do not have anything fused. That would be great to see a system diagram from a pro, just to gain some insight.
thanks
snowgoer540 wrote: I appreciate the kind words, but I am far from a pro
snowgoer540 wrote: One suggestion I would have is to look at the wiring diagram for the Tormach 1300PL table. They sell tables commercially, and they also post wiring diagrams in their manuals to help people diagnose faults themselves. In fact, I borrowed some of the wiring on my table from their 1100S3 mill manual, (the estop contactor circuit for one) as I have one of those and I could also look at the hardware when I was confused.
snowgoer540 wrote: Lastly, I was reminded that the diagram shows the shield wire going to ground. That is not correct per PCW:
forum.linuxcnc.org/plasmac/39899-doing-o...h-one-thcad10#180352
forum.linuxcnc.org/plasma-laser/40712-th...ions?start=30#197468
forum.linuxcnc.org/plasma-laser/40712-th...ions?start=30#197472
However, I am unsure what that looks like in the diagram because the posts seem to be a bit contradictory (in one post he says +in of the THCAD, and in the other he says "closest to the workpiece", and they are not the same connection...
EDIT: There is this one where PCW blessed it in the next post, but ever time I think back to all that, it still makes my head hurt. forum.linuxcnc.org/plasmac/40214-big-ohm...blem?start=30#184885
