plasmac message error
- beauxnez
- Thank you received: 10
23 Dec 2020 16:51 #192986
by beauxnez
it is a parallel port
Replied by beauxnez on topic plasmac message error
Not sure what io you have but if it is a 7i96 then it would something like this in your connections.hal file:
hm2_7i96.0.gpio.008.in_not
- snowgoer540
- Thank you received: 907
23 Dec 2020 18:27 #192996
by snowgoer540
It's the same thing, just take whatever your current pin is and add "-not" to the end of it. Also, I think it can be "-not" or "_not" and both will work the same.
Replied by snowgoer540 on topic plasmac message error
- beauxnez
23 Dec 2020 21:34 - 23 Dec 2020 21:36 #193030
by beauxnez
Thank you
I removed -not
I removed -not
Last edit: 23 Dec 2020 21:36 by beauxnez.
- beauxnez
26 Dec 2020 16:10 - 26 Dec 2020 16:13 #193238
by beauxnez
the herocut 55i works well for the moment no bug at the computer level to succeed in making it work I must simulate arc Ok with an interuptor because if not I have an error message arc valid signal lost
you need a pull resistor up or other on the arc exit Ok on the herocut?
Last edit: 26 Dec 2020 16:13 by beauxnez.
- Thank you received: 7496
26 Dec 2020 17:39 #193243
Replied by tommylight on topic plasmac message error
The torch should be up before starting a cut. Having it low will void the probe speed and run it at setup speed.
- phillc54
- Thank you received: 2100
26 Dec 2020 22:17 #193252
by phillc54
+1.
See the third sentence: linuxcnc.org/docs/devel/html/plasma/plas....html#_using_plasmac
I have been giving some serious thought to having the filter program automatically place a Z move to just below the max height for the first cut.
Replied by phillc54 on topic plasmac message error
+1.
The following user(s) said Thank You: tommylight, snowgoer540
27 Dec 2020 10:58 #193282
I would not bother with it, on machines with limit switches it is not an issue, and adding the "material 0" button takes care of that. I use a laser for material edge finding so i have to use that feature. Although adding a G53 Z10 or simillar to the top of the gcode should also do.
- snowgoer540
27 Dec 2020 11:13 - 27 Dec 2020 11:49 #193288
by snowgoer540
I'm a fan of this. My touch-off button is modified to have a G53 Z0.196 so that when I zero X and Y I dont forget to jog the torch back to the top.
It seems it would save a lot of new users a lot of headache.
Last edit: 27 Dec 2020 11:49 by snowgoer540. Reason: Fix quoting
- beauxnez
28 Dec 2020 18:30 - 28 Dec 2020 18:31 #193374
by beauxnez
hello, I did several tests, with a Relay which simulates arc ok and with a reed sensor as described in the plasmac guide, same result
if I deactivate arc Ok and put 4 seconds of delay it works
Last edit: 28 Dec 2020 18:31 by beauxnez.
- beauxnez
16 Jan 2021 19:57 - 16 Jan 2021 20:00 #195565
by beauxnez
hello
my herocut 55x and the Thc102 is working perfectly www.ebay.com/itm/THC-Torch-Height-Contro...utting-/264991610425
I wanted to know if it is possible to make the torch not go up at the end of the gcode?
Last edit: 16 Jan 2021 20:00 by beauxnez.
Time to create page: 0.315 seconds
