plasmac message error
- Thank you received: 4153
21 Nov 2023 09:44 #286153
Ref; linuxcnc.org/docs/stable/html/plasma/pla...mer.html#_cnc_plasma
Replied by rodw on topic plasmac message error
Thats Odd because height to voltage is a very linear relationship as this chart from 16000 readings showsThe THC adjustment is not linear, rather sawtooth, what do I need to adjust?
- Thank you received: 7496
21 Nov 2023 23:25 #286205
Replied by tommylight on topic plasmac message error
Is the Z axis scaling set properly?
I would venture a guess at "not"
- beauxnez
- Thank you received: 10
24 Nov 2023 06:03 - 24 Nov 2023 06:10 #286383
by beauxnez
Replied by beauxnez on topic plasmac message error
Sorry if I don't respond to everyone, I'll take note of your advice and I'll do some tests during the day (I'm off today)
Last edit: 24 Nov 2023 06:10 by beauxnez.
- beauxnez
24 Nov 2023 06:16 - 24 Nov 2023 06:50 #286384
by beauxnez
"Is the Z axis scaling set properly?
I would venture a guess at "not" "
if it is this section5.6. Initial Setup no I did not
Last edit: 24 Nov 2023 06:50 by beauxnez.
- beauxnez
24 Nov 2023 06:19 - 24 Nov 2023 06:50 #286385
by beauxnez
"Thats Odd because height to voltage is a very linear relationship as this chart from 16000 readings shows
Ref; linuxcnc.org/docs/stable/html/plasma/pla...mer.html#_cnc_plasma"
Je veux dire que lors de la découpe la distance entre la tôle et la torche est de 1 mm à 3 mm
- beauxnez
03 Dec 2023 14:37 - 03 Dec 2023 19:24 #287096
by beauxnez
Good morning,
I've done several tests and it doesn't change anything.
setp plasmac.arc-lost-delay 0.4
I took the arc ok on the thc, on the plasma I also have an arc output ok and a reed sensor same result
the only configuration that changes in the custom.hal is:
step db arc- ok délai 10
the more I increase the delay, the longer I can cut
this could come from latency? because I re-tested I am at 55000
my new pc is a 7th generation core i5 with 8 gigabytes of ram
Last edit: 03 Dec 2023 19:24 by beauxnez.
Time to create page: 0.338 seconds
