plasmac message error
5 years 10 months ago #191846 by beauxnez
hello
i'm trying to configure plasmac but i can't do it there is an error message
I use a parallel port card as in the photo below
Thanks for your help
5 years 10 months ago #191848 by tommylight
Replied by tommylight on topic plasmac message error
You have two lines together in the plasmac_connections hal file.
Separate those lines.
5 years 10 months ago - 5 years 10 months ago #191857 by beauxnez
Replied by beauxnez on topic plasmac message error
tommylight wrote: You have two lines together in the plasmac_connections hal file.Separate those lines.
Thank you for the quick reply
I'm sorry but with but weak knowledge like that, but still error
Last edit: 5 years 10 months ago by beauxnez.
5 years 10 months ago #191870 by tommylight
That wont work, you have the same pins used for parallel port AND a Mesa 7i96 ?????
Make a new config, use stepconf, NOT pncconf.
After you get that running and tuned properly, make a copy and use the configurator for PlasmaC
5 years 10 months ago - 5 years 10 months ago #191884 by beauxnez
I went through stepconf
no time tonight, i will stay next week thanks
5 years 10 months ago - 5 years 10 months ago #191917 by snowgoer540
Replied by snowgoer540 on topic plasmac message error
I will update the user manual to make the parallel vs mesa examples stand out a bit more to make this a bit more clear :)
Last edit: 5 years 10 months ago by snowgoer540.
Time to create page: 0.070 seconds
