- Thank you received: 10
plasmac message error
if I deactivate arc Ok and put 4 seconds of delay it works
my herocut 55x and the Thc102 is working perfectly
I wanted to know if it is possible to make the torch not go up at the end of the gcode?
Glad you got it working, but please do set some 70 Euro aside for a Mesa THCAD.
I have no affiliation with Mesa, they just make some very good electronics and i use them a lot, although a single THCAD costs me over 150 Euro to get it here due to customs and stuff.
No, it is a normal part of the PlasmaC cut sequence.beauxnez wrote: I wanted to know if it is possible to make the torch not go up at the end of the gcode?
tommylight wrote: Sorry to burst your bubbles, but that is a very, very bad board design, the 300V plug is right next to the USB port and the rest of low voltage electronics, a single diode on the input, very ......... never mind.
bad choice on my part, the future will tell me and I will give you a feedback
merci
