- Thank you received: 10
plasmac message error
2 years 11 months ago #284956
by beauxnez
Replied by beauxnez on topic plasmac message error
hello
my plasmac no longer works the inputs on my DB25 card when I short circuit between the gnd and pins 11,12,10 nothing happens.
I think it doesn't work. Is there a way to test them?
I can no longer find the user manual?
2 years 11 months ago #284982
Replied by tommylight on topic plasmac message error
Did you try to cut something without the clamp attached to material?
First check the cables and connectors, make sure they are plugged in properly.
Use "show hal configuration" from the machine menu, on the right side choose the "watch" tab, on the left expand "pins", paraport, then click on pins 10,11,12,13,15.
Short the inputs to GND, do the LED's on screen change color?
2 years 11 months ago - 2 years 11 months ago #284999
by beauxnez
Last edit: 2 years 11 months ago by beauxnez.
2 years 11 months ago #285026
OK, that leaves us with a configuration error and with a question, why are you not switching to QtPlasmaC ?
Attach the zipped configuration folder so we can have a look.
2 years 11 months ago - 2 years 11 months ago #285081
by beauxnez
on your advice I installed debian12 linuxcnc 2.9.1 qtplasmac works ,same problemimage missing /media/kunena/emoticons/devil.png
I installed debian12 linuxcnc 2.9.1 qtplasmac works same problem
if I put pin 10 connect to the gnd I have ok arc which lights up
if I put pin 13 connect to the gnd I have float swith which lights up
if I put pin 11,12 connect to the gnd, no light comes on on the qtplasmac interface
if I swap all the inputs between them, float switch and arc ok works but not up and down
2 years 11 months ago #285085
by phillc54
Replied by phillc54 on topic plasmac message error
The up and down leds will only light if activated by the THC, they are connected directly to the component, not to the HAL pins.
Time to create page: 1.344 seconds
