plasmac message error
5 years 10 months ago - 5 years 10 months ago #191976 by beauxnez
Replied by beauxnez on topic plasmac message error
snowgoer540 wrote: I will update the user manual to make the parallel vs mesa examples stand out a bit more to make this a bit more clear :)
the update has been made
I understand better
Last edit: 5 years 10 months ago by beauxnez.
5 years 10 months ago #192003 by snowgoer540
Replied by snowgoer540 on topic plasmac message error
I understand better
Glad to hear it, if you find anything else that’s confusing please let me know, feedback helps!
5 years 10 months ago - 5 years 10 months ago #192927 by beauxnez
it works ?
i have herocut 55x non hf blowback plasma with arc output Ok
the light on linux cnc is on even with the plasma disconnected, how to invert signal in plasmac file. connection. HAL
5 years 10 months ago #192928 by phillc54
Replied by phillc54 on topic plasmac message error
Not sure what io you have but if it is a 7i96 then it would something like this in your connections.hal file:
hm2_7i96.0.gpio.008.in_not
5 years 10 months ago #192986 by beauxnez
phillc54 wrote: Not sure what io you have but if it is a 7i96 then it would something like this in your connections.hal file:
it is a parallel port
5 years 10 months ago #192996 by snowgoer540
It's the same thing, just take whatever your current pin is and add "-not" to the end of it. Also, I think it can be "-not" or "_not" and both will work the same.
Time to create page: 0.249 seconds
