- Thank you received: 10
plasmac message error
2 years 11 months ago #285942
by beauxnez
Replied by beauxnez on topic plasmac message error
I found, you must not check ignore arc ok otherwise the thc does not work
I set the step db arc-ok delay to 5000 otherwise I had arc ok lost
The THC adjustment is not linear, rather sawtooth, what do I need to adjust?
youtube.com/shorts/87E32FPU6MA?si=Q01okq_GWM9qxRJL
2 years 11 months ago #286133
by phillc54
Replied by phillc54 on topic plasmac message error
Yes, that is correct.I found, you must not check ignore arc ok otherwise the thc does not work
That seems to be quite a large value, have you tried doing it this way.I set the step db arc-ok delay to 5000 otherwise I had arc ok lost
The only adjustment for external THC's from within QtPlasmaC is THC Speed%.The THC adjustment is not linear, rather sawtooth, what do I need to adjust?
2 years 11 months ago #286153
Ref; linuxcnc.org/docs/stable/html/plasma/pla...mer.html#_cnc_plasma
Replied by rodw on topic plasmac message error
Thats Odd because height to voltage is a very linear relationship as this chart from 16000 readings showsThe THC adjustment is not linear, rather sawtooth, what do I need to adjust?
2 years 11 months ago #286205
Replied by tommylight on topic plasmac message error
Is the Z axis scaling set properly?
I would venture a guess at "not"
2 years 11 months ago - 2 years 11 months ago #286383
by beauxnez
Sorry if I don't respond to everyone, I'll take note of your advice and I'll do some tests during the day (I'm off today)
Last edit: 2 years 11 months ago by beauxnez.
2 years 11 months ago - 2 years 11 months ago #286384
by beauxnez
"Is the Z axis scaling set properly?
I would venture a guess at "not" "
if it is this section5.6. Initial Setup no I did not
Time to create page: 0.429 seconds
